how much power can u get with the cheap stroker?
  • MrK
    • Jan 2006
    • 709
    I don't know if the chip is any different, but the Mahle catalog lists specific pistons for the "M20B27 mtech." They are domed, and look more like B25 pistons than eta pistons, so the pistons must be different.
    This is your M20 on steroids:
    • backtrail69
      • Jul 2005
      • 4471
      I wonder if they used the 130 or 135mm rods?
      :: PNW Crew ::
      '87 325 4dr, '74 2002
      • MrK
        • Jan 2006
        • 709
        I believe they used 135mm (B25) rods and shortened pistons, but I'll check and make sure.
        • StereoInstaller1
          GAS
          • 22679
          Dude...get us some part numbers!
          Closing SOON!
          Thanks for 10 years of fun!
            • 34847
            if they are even still available, I bet the cost of a set of these pistons would be about the same as custom forged 86mm pistons. not worth it IMO..
            • Andreas
              • Jul 2006
              • 107
              In South Africa we also had factory 2.7 models called 325is. The 325is Evo II was rated at 155 KW (210 hp).
              I posted some pics of 325i and the 2.7 Mahle pistons as well as profile comparisons on our South African forum.
              The 2.7 engines use the 135mm conrods. The gudgeon pin is higher up in the piston to compensate for the increased stroke of the crank.
              • fengshui
                • Dec 2006
                • 18
                Super Eta piston compression w/ the 885 head is 8.5:1. I made a 327i (2.7L which is what an eta has stock) out of my Super Eta by carrying all the "i" components over. Metric Mechanic states that this is good enough for ~170-180hp and good for ~100K miles when driven hard. I'd say it pulls much better then a stock super eta. I have a 3.25:1 LSD on it as well that helps with pulling. Stock w/ the 3.25:1 LSD made it an even race to 60mph w/ Andy's Euro 1986 325is.
                Now that it is a 327i, who knows. ;)
                -Chris
