2.7 in a 325is?
  • kmsnsx
    • May 2007
    • 63
    2.7 in a 325is?
    I'm looking at a 1989 325is at a local dealer and he claims it has the "stronger 2.7L motor" Is that even possible unless a swap was done?
  • browntown
    • Jun 2004
    • 3524
    the vin on the engine should match the car if you're buying from a dealer.
    • JGood
      • Jan 2004
      • 7959
      The stock 2.7l is the 325e engine, made from 84-87 (88 model year had a variation of this motor in the normal 325, not 325i). If it has this engine (m20b27), someone did a serious downgrade, and went through an electrical nightmare for a serious loss of power. I wouldn't call it stronger, the reason they last longer is because people aren't revving them to 6k.
      So, find another car, or verify it still does have the correct, stock, m20b25 2.5l engine.
      e30 restoration and V8 swap
      24 Hours of Lemons e30 build
      • kmsnsx
        • May 2007
        • 63
        Is there any way to tell just by looking which motor it is?
        • swimstarguy
          • 132
          The intake manifold on the eta will be more "rectangularish" than the "i". Also, try taking for a test drive and rev it up and see where it breaks.
          ~Zar4
