Vacuum Question
  • maniacmatt
    • Feb 2007
    • 483
    Vacuum Question
    So I am swapping a 1990 m20b25 into my '84 325e but you probably already know that.
    Anyway the engine did not come with the vacuum lines from the booster to the throttle body so I went onto bmwfans.info looked at the parts diagram and picked up this from a wrecker.
    However now that I look at my intake boot I have no place for that little plastic Y to connect.
    As well there is only one connector on the side of my throttle body.
    So this brings me to the conclusion that the vacuum system on a 1990 (my engine) and a 1989 (wrecker parts) are different.
    So what do I need to make this work, part numbers and any other help would be hugely appreciated.
    • 34847
    there is a different intake boot that is used with that vacuum hose you have. mine is a 10/90 build date and it has the same thing.
    • maniacmatt
      • Feb 2007
      • 483
      Would you mind taking a picture of yours
