varible TPS
  • 0000000000
    • 473
    varible TPS
    What kind of tps can i use on a m20 that is a varible tps with out have to make new mounting points...
    Im using a SAFC so thats why i need a veriable tps...
  • 0000000000
    • 473
    sorry found what i needed....
    i need a 525i automatic tranny variable TPS...
    anyone have one for sale
      • 34847
      the 525i one doesn't need an adapter plate, but it needs a different connector
      the E36 TPS needs an adapter plate, but the connector is the same as the standard E30. and adapter plate should be very easy to make (that's what I'm doing). at least, I'd rather make an adapter plate than hack into my wiring harness..
      • Mr Deagle
        • 1121
        I used a cnc adapter plate, and a bosch tps, same connector.
        gives it that oem look install
        • NC325iC
          • Mar 2004
          • 6565
          not everyone has a cnc machine guy
          • euroshark
            • Apr 2006
            • 3491
            I do, I keep the machine and the operator in the backyard.
            • Mr Deagle
              • 1121
              I have like 100 in stock, if you are intrested i may be able to set you up with one
              • NC325iC
                • Mar 2004
                • 6565
                there was to be a comma btw machine and guy for clarification, by that i mean i was calling deagle guy
                  • 34847
                  is this for the E36 tps?
                  you don't *really* need to CNC anything. all you really need is a thin sheet of aluminum, a drill, and a pair of snips.
                  • Mr Deagle
                    • 1121
                    No, it is for porsche-bosch TPS
                    of course you dont *really* need to, but it makes it so much cleaner
                    • NomadE30
                      • Mar 2007
                      • 236
                      can you use a e36 variable tps on a stock ecu? since i need to replace my tps would i be able to do that so i didn't have to worry about it when megasquirt comes up?
                      • browntown
                        • Jun 2004
                        • 3524
                        volvo 850's have variable bosch tps that are used in lots of different applications. run about 40-50 bux new.
                          • 34847
                          no
                          • NomadE30
                            • Mar 2007
                            • 236
                            no
                            thank you
