Can you pull the tranny out without pulling the motor out?
  • OSM e30
    • Jan 2007
    • 55
    im going to be changing the transmission from a automatic to manual transmission. and i was wondering if its easier to pull the whole motor out or is it possible to just pull out the transmission?
    • 37829
    With the right tools you can leave the motor in the car. If you're limited on things, it might make it easier for you to pull it all out, do a once over on everything.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • Teaguer
      • Sep 2004
      • 6167
      Only special thing you need is a long assed extension to get to the bolts by going over the trans .
      And the ability to hold a 17mm wrench on the starter nuts while you get to the bolts with the extension .
      • erik325i
        • Jan 2005
        • 3567
        Yes, it is possible to drop the tranny without pulling the motor. I've done it a few times.
        -Erik
        • OSM e30
          • Jan 2007
          • 55
          is it difficult to swap the transmissions? what do i need to change? because i have a wrecked car at home that has a manual tranny and i have another an e30 thats automatic that i want to make manual. so i was wondering what i would need to take out of the car with the manual tranny
          • Teaguer
            • Sep 2004
            • 6167
            I'm just going to add :
            If you have to ask if the trans can be dropped without removing the engine then maybe you don't have hte skills to be performing a auto-manual swap .
            • OSM e30
              • Jan 2007
              • 55
              Dude what the hekk im just askin what parts i need ta take out to make life a little easier and i know the tranny can be dropped with out removing the engine but i was wondering which is easier to pull out the whole motor or just the tranny
              • Teaguer
                • Sep 2004
                • 6167
                OK then .
                You should read up on the 5-spd swap threads and then you should know what is involved before jumping into it .
                Then ask questions if you run into a problem but don't expect people to walk you through the swap .
                Tell us what year the donor car and recipient cars are .
