eta i head compression.
  • TopOfTheLine89
    • Jun 2007
    • 919
    I have a 87 eta, I know people say you can't put the i head on because you loose alot of compression with the regular eta pistons. Does anyone know what my compresion would be with the i head? Cause if i turbo it the low compresion would be a good thing so im wondering how low the compresion would be.
    97 tacoma 5 spd 4 cylinder
    2001 330ci 5 speed
    83 733i 5 speed, (FS)
  • BigD
    • Jul 2006
    • 1085
    You know what... an old timer BMW mechanic in Vancouver told me that the whole loss of power with i head swap is bogus. Yeah the compression is lower but the cam is still bigger and hotter, and the valves are larger. There is still a very nice power gain. Again this is 2nd hand info but I do know that this guy has done it, along with 1000 other weird things with BMWs. Just saying that before you go believing gut feelings, find someone who has tried it.
    • Jordan
      • 12916
      Compression will be around 8:1.
      Assuming you swap an entire I top end on, and convert to Motronic 1.3 you will see some modest gains. Really nothing worth the effort though IMO.
      https://mtechniqueabs.com/
      • TopOfTheLine89
        • Jun 2007
        • 919
        Thanks guys, that is exactly what i wanted to know. Cause 8:1 compression would be great for a turbo setup.
        Is motronic 1.3 just the ecu? what all would need to be changed? injectors?
        2001 330ci 5 speed
          • 34844
          you'd want pretty much everything - engine harness, injectors, sensors, etc. basically everything above the block. you also need the front crank sensor and harmonic balancer/toothed wheel.
          • TopOfTheLine89
            • Jun 2007
            • 919
            damn, maybe ill just stick to my plans of swapping in the i cam,valvesprings and intake manifold then call it a day. Would be way safer to turbo though with the 8:1 compression.
            what would happen if i swapped nothing?lol. high reving ETA performance?
            2001 330ci 5 speed
            • BigD
              • Jul 2006
              • 1085
              You mean just turbo an eta? Nothing spectacular... well from a performance standpoint. The cam is still too lame so it's not gonna rev very high or perform well while there but you'd float a valve.
              By the way, a little off topic, why do people obsess over having a forged crankshaft? Do these really ever break? I've seen broken pistons and rods but crankshafts???
                • 37833
                You won't be high revving without the i Motronic setup.
                Grover Beach, California
                BimmerHeads.com
                • M20Curtis
                  • Oct 2004
                  • 27
                  You won't lose power, I run an '84 e with i upper end, cone filter, and free flow exhaust, on stock chip I put down 138rwhp and 151lbft of torque. Don't listen to anyone saying it doesn't work, I can pull harder than any stock 325i I know.
                  • ZeroCool
                    • Mar 2007
                    • 28
                    Any more details on how you did this?
                    Is it really just as simple as the i upper end and the computer?
                    Is the eta's bottom end capable of reving up to like 6k?
                    I'd love to do this to my eta as it should be pretty easy to get the parts cheaply over time.
                    • NomadE30
                      • Mar 2007
                      • 236
                      Yes the eta bottom end is able to run that high, only problem limiting eta is the single valve springs and 4 oil journals instead of 7. And the only thing limiting from there is Rocker arms and harmonic balancer alogn with you don't make any power past 7k
                        • 37833
                        That's not that great of numbers.
                        BimmerHeads.com
                        • M20Curtis
                          • Oct 2004
                          • 27
                          Yes its that simple of a bolt on and I know that isnt that great of numbers but for a 100k+ bottom end, nothing rebuilt, and $250 invested, it sure kicks a stock e cars ass.
                          • TopOfTheLine89
                            • Jun 2007
                            • 919
                            What electronics did you swap? How hard was it?
                            2001 330ci 5 speed
                            • M20Curtis
                              • Oct 2004
                              • 27
                              I got a harness with my 325i head I bought and it replaces the stock harness. It really wasnt that hard, everything is plug and play. You just need to also replace the front harmonic balancer and use the new crank sensor and it should fire right up.
