eta i head compression.
  • TopOfTheLine89
    • Jun 2007
    • 919
    Anyone have a 2.7 with just i valvespring, i camshaft, i intake and TB dyno results to compare to m20curtis's? Mr. Anderson maybe?
    97 tacoma 5 spd 4 cylinder
    2001 330ci 5 speed
    83 733i 5 speed, (FS)
    • Bimmerboy91
      • Feb 2007
      • 622
      dead thread come back to life.
      ive been thinking of doing the 327i thing. stick on an i head, i intake and the computerto my block. but is it really that easy? and what would happen if you swapped out the computer from my super eta and put in an i computer?
      • digger
        • Nov 2005
        • 6170
        I head on ETA bottom end = 8.42:1
        I head with I piston ETA rod and ETA crank = 7.97:1
        those are nominal numbers
        • digger
          • Nov 2005
          • 6170
          do you have a SETA? If so the cam and inner valve springs are the only thing in the head needing to be swapped to make it a I head and at the same time a good refresh will help things alot
          • Bimmerboy91
            • Feb 2007
            • 622
            how do i know if i have the SETA? my car's title says its a 325/e and the rear badge says "325" and its got the "is" accessories on it. never owned an eta so im not sure
              • 34844
              they were only sold in the 88 model year - if your car is an 87 it's just a regular eta.
              • kenika65
                • Aug 2007
                • 1336
                Originally posted by TopOfTheLine89
                Is motronic 1.3 just the ecu? what all would need to be changed? injectors?
                Read this for a list of everyting you should change when upgrading to 1.3 Motronics
                1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
                1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
                • rThor432
                  • Feb 2007
                  • 3907
                  You can get decent numbers with the i head. Check out post #12. http://www.r3vlimited.com/board/showthread.php?t=97872
                  • SamE30e
                    • Sep 2007
                    • 4319
                    The power loss is bogus, it was posted on here last month I think. Some dude in toronto did the swap but he used mega squirt, it made 130hp or something like that I think.
                    Edit: ^^ thats it.
                    1985 325e 2.8 Turbo VEMS
