528e head and 1989 525i
  • norwood e30
    • Mar 2007
    • 442
    Hi i just found my 1989 525i head but i have a 1987 528e motor am i able to put the 525i head on the 528e block. basically swap it?
  • SpecM
    • Oct 2005
    • 4531
    -It will work and run but don't expect huge hp gains
    1989 cirrisblau-metallic 325i
      • 34847
      you'll have ~8:1 compression. It will work, but as stated above, don't expect too much.
      • SS Ball3r
        • Sep 2007
        • 119
        you will need new pistons to see a good gain.
        • norwood e30
          • Mar 2007
          • 442
          Oh not for the Hp just to replace my head because the 528e head is bad and i fonud my 89 525i head and i wanted to change it soon. thank you guys so much for the replys
          • norwood e30
            • Mar 2007
            • 442
            valve seals
            Im also going to change the valve seals on my 528e head. How many do i need is it 12 seals? or more not really sure didnt look.
            • backtrail69
              • Jul 2005
              • 4471
              If you buy a head gasket kit from a company like reinz they come with all 12 valve seals, HG, intake, exhaust etc etc.
              :: PNW Crew ::
              '87 325 4dr, '74 2002
