damn oilpan
  • eyagel
    • Jan 2007
    • 756
    damn oilpan
    so why is my oilpan sitting so low?? rubber engine mounts? i am running votglands and my pan is litteraly like 3.5 inches from the ground..this shit sucks...how do i get it higher??? i am becoming the roads bitch
  • T.Dot_E30
    • Mar 2004
    • 286
    Known issue with lowered m20s.
    Watch how you drive.
    • pwforprez
      • Apr 2007
      • 71
      put spacers on your engine mounts. may be abler to get an inch or so if your lucky
        • 37832
        Don't space your engine. Be more cautious.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • backtrail69
          • Jul 2005
          • 4471
          I don't have any problems. If you lower your car get firm springs, good shocks and don't drive like an idiot. I have been driving my DD on H&R race and Billy sports for 13k miles without any issues. The PO didn't have any either. Not one scratch on the pan.
          :: PNW Crew ::
          '87 325 4dr, '74 2002
          • strad
            • Jan 2007
            • 241
            I would certainly make sure your motor mounts aren't collapsed. But I would not mess around with spacers, since you'll knock your driveline out of alignment and kill the u-joints and/or csb that much faster.
            The current fleet:
            1992 325ic: 148k-171k miles
            1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
            1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
            • ethree
              • Aug 2007
              • 1213
              • sticksdaman
                • Apr 2005
                • 2987
                sagging engine mounts could be good for roughly an inch of clearance
                for wat its worth
                im on vogtlands as well
                Originally posted by ebelements
                Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
                • eyagel
                  • Jan 2007
                  • 756
                  i used some other mounts, did the job just fine, houston streets are bad i drive super cautious but ive been through like 7 pans, so i raised it up..now its sitting higher than the cross member and steering rack..super high
                  • Teaguer
                    • Sep 2004
                    • 6167
                    Granted Houston roads suck but if you've gone through 7 pans then you're NOT driving cautiously ......much less super cautiously .
                    Slow the fuck down and watch where you are going . ;)
                    • SchnellerVert
                      • Sep 2005
                      • 3948
                      7 pans? That must be a record. I haven't killed one yet.
                      • indecline
                        • Sep 2007
                        • 244
                        I demolished one completely racing a GMC truck.
                        It was a bitch to remove (had to hoist the engine and loosen motor mounts)
                        It ran the same after the install, thank god.
                        1989 325I(M20B25US)|KAMotors CAI|Bilstein Sports|H&R Sports|ST Sways|SSSquid Tune|Red46 Sump Armor|
                        • strad
                          • Jan 2007
                          • 241
                          I haven't trashed one yet either. But then, I'm running oem suspension too ;)
                          I did replace a trashed gasket, but what do you expect of 15-yo gasket material? I wouldn't say the install was easy, but it wasn't the most difficult diy I've encountered either.
                          The current fleet:
                          • eyagel
                            • Jan 2007
                            • 756
                            haha they suck, after the first one it scared me because i was going like 20 on the freeway, i drive slow anyways..especially over bumpy roads..but they still get creamed. but i dont have to worry now.
