Unknown 3 pin wire hanging out...
  • denisbmwm5
    • 347
    I just bought another e30 after not owning one for over a year. Yesturday i picked up a 91 325i coupe cheap and been doin some work to it.
    I found a 3 pin wire just hanging down by the alternator and cant seem to find what it leads to. It Not the pulse sensor or the crank sensor wire.
    heres a pic
    I don't remember how many wires are in the connector, but the oil level sensor is in that general area as is the evap purge valve, ICV, and TPS.
    • 85Ecoupe
      • Sep 2007
      • 81
      looks like the TPS to me
      • NC325iC
        • Mar 2004
        • 6565
        i agree with tps, it could be the tps though if its long enough
        the oil level sensor wire is a male connector
        evap purge valve is 2 wires
        • e30 gangsta
          • 3877
          tps
          • cowmoo32
            • Mar 2007
            • 34
            Haha, I was just about to post asking about the same thing. I just noticed mine hanging today. This wouldn't have anything to do with a rough idle would it?
            V1 - Debadged - Painted Reflectors - Black Kidneys
            1987 325e
            • NC325iC
              • Mar 2004
              • 6565
              that is long enough to be your icv
                • 34844
                why the hell is it zip tied way over there? if it is your TPS, it would definitely affect idle, and essentially retard your timing and fuel maps to the "part throttle" area.
                our wiring harnesses are very simple.. I don't get how you guys can lose where things go.
                • DaveSmed
                  • Apr 2007
                  • 1407
                  To the second guy asking about a plug, that is for your barometric pressure sensor. Should be somewhere on your airbox.
                  -Dave
                  2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                  Need some help figuring out the ETM?
