Question for 3.0l stroker guys...
  • Slyder
    • 348
    Has anyone experienced a fitment issue with using a single-mass flywheel (standard size from the m20b25) with the s50 crankshaft?
    The problem I'm experiencing is that the flywheel and starter gears are not meshing, and therefore cannot turn the motor over. The flywheel is the 8lb JB Racing model # 520-060-228
    Things that have been done so far...
    1. Tried installing a new starter...no change
    2. Double checked part number on the flywheel...it's correct
    3. Had a local shop pull the transmission off for me to check things out (I needed a break) and was told that the flywheel appears to be sitting too far away from the backside of the block...so the starter gear is not making contact. Don't know how this is possible. The flywheel is installed as required by JB and I've never heard of anyone having this problem before. I have not seen this with my own eyes yet and probably won't be able to until Monday (and pics).
    Pics from the install...
    Those of you that have built a 3.0l stroker...what flywheel/clutch setup are you using? Not really looking for speculations here...mostly just what parts you're using.
    - Jason
    • 34844
    there is a little spacer thing that goes between the flywheel and the crank. did you use that? maybe add another? I've never heard of anyone having problems with the flywheel on a stroker before.
      • 34844
      http://www.realoem.com/bmw/showparts...37&hg=11&fg=20
      • Jordan
        • 12916
        #10 is a tq spreader plate, it goes between the mounting bolts and the flywheel.
        https://mtechniqueabs.com/
        • PiercedE30
          • Apr 2005
          • 4220
          OT: Nice clutch setup, I've got the exact setup, down to the flywheel. I've even got the same crank, but it's all in an M50. Let me know how you like the clutch setup since I, more than likely, will not be able to try it out until mid to late January, all things going in my favor.
          My 2.9L Build!
          • Slyder
            • 348
            Just posting back to close the issue out. Turns out I was missing the dowel pins between the bottom of the block and the transmission. Very stupid brainfart on my part...just didn't realize they weren't there when I reassembled everything.
            The motor fired right up after that.
            - Jason
            • whiltebeitel
              • Apr 2007
              • 2098
              Will you dyno it?
              '89 325i track sloot
              '01 530i daily
              -Enginerd
              • Slyder
                • 348
                Of course. But not before I break the motor in for about 1500 miles. Once I hit that mark, I'm going to take it in and get it dyno tuned and see just what kind of power it's putting out.
                Here's a little teaser from tonight...
                - Jason
                  • 34844
                  sounds good. what are you going to use for engine management?
                  • NC325iC
                    • Mar 2004
                    • 6565
                    seriously though it looks like you forgot #10 from nando's post before
                    also i have the same clutch setup (depending on what stage you went with) stage 3 is the one i have, i love it, driving a "regular" clutch now makes me angry weak engagement and such. enjoy
                    • Slyder
                      • 348
                      Mine is also a Stage 3. I haven't experienced the full grabbing power of it yet and won't really be trying for it until I get the clutch broken in. I don't want to end up glazing the disc.
                      The engine management planned is a standalone MegaSquirt system. I just don't plan on swapping it in until the motor is solid. I want to make sure the first 1500 miles goes without issue, then add the next big piece.
                      - Jason
