1.3 Motronic Up-Grade & 2.7i How To
This is a sticky topic.
  • EtaSport
    • 2853
    #106
    Yea, my 2.7 would really fly with the 3.25 diff, it was good for about 140 on a straight.
    -I will be this summer putting together a 2.7i using an I head. I havent had any experience with this set-up but I am hoping for pretty good results. The head will be milled slightly to help the compression but without getting the timing too jacked up.
    Old and improved:
    • rjteeter
      • 75
      #107
      Can some one post a picture of what the "i" reference sender mounts to. Also Could I possibly get a picture of the wiring on the starter and alternator. Ive lost track of how things are wires since I tore my car apart last summer
      flickr
      ifuckindrift
      • kenika65
        • Aug 2007
        • 1336
        #108
        Im guessing i starter or e?
        1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
        1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
        • rjteeter
          • 75
          #109
          Aw man that is great. I was looking completely in the wrong spot.
          My starter is an "e" starter. Will that be a problem other than a different connector on the "i" harness?
          Also I'm not sure if this is because of something not being hooked up properly but my starter only spins. It does not kick out and engage with he flywheel. Any suggestion on that? can a starter go bad just from sitting for a year and not being used?
          flickr
          ifuckindrift
          • kenika65
            • Aug 2007
            • 1336
            #110
            Sounds like your starter is stuck, no biggy get a rubber hammer or put a rod on the starter then hit the rod with a hammer when you engage it, hopefully it will pop out and work, if not it is a bitch to get the starter out if you dont have the correct tools. Before you pull it out make sure you have a fully charged battery.
            as for the starter wires I do remember changing a wire connection on the small wire, what I did is cut the square connector off of my eta harness and put it in place of the circle connector on the i harness. I will be able to get you a picture tomorrow.
            • rjteeter
              • 75
              #111
              no start
              All rite, the starter is fine and the solenoid is not getting power. When I run a wire to the solenoid pin to the power pin on the starter it turns over but it wont turn over with the key.
              I have some wires that aren't connected to anything, maybe one of these are the problem???
              http://tunerslut.com//images/rsgalle...l/_MG_2934.JPG
              flickr
              ifuckindrift
              • kenika65
                • Aug 2007
                • 1336
                #112
                Think of a 2.7i this way your 82-87 325,e,es has the 2.7L 9.0:1 compression M20 and the 87-92 325i,is,ix have the high performance 2.5L 8.5:1 compression M20. Now if you have both an e and an i then take all of the high performance i parts off and bolt them on to the e and you will have a high performance, high torque 9.0:1 compression 2.7L M20. This i the quick way. The long way is putting on the i head which is not necessary for this quick performance upgrade.
                Now if you have an i car then I am going to suggest getting any 2.7 crank and use your i rods and buy custom pistons that already have valve reliefs cut in them and at a compression of your choice.
                • E30Kaiser
                  • Mar 2008
                  • 1790
                  #113
                  Okay I got a question that I have heard multiple answers to, so let me ask it here. My 2.7 revs to about 5500 and the limiter cuts in, I am wondering why it doesn't go at least until the I's limit. I didn't do the swap, bought the car with it, here is what the PO put in the for sale ad:
                  Motor:
                  88 325e
                  M30 injectors
                  M30 AFM
                  3.0 bar FPR
                  "i" head swap
                  K&N Filter
                  Head swap:
                  Re-manufactured "i" head
                  "i" intake manifold
                  "i" Throttle body
                  173 ECU
                  "i" cluster
                  solutions?
                  "We're not here for a long time, we're here for a good time"-Colin McCrae
                  • EtaSport
                    • 2853
                    #114
                    He doesnt have the right chip installed. Sounds like its only got an e chip that is good for 5500 rpm. You need to call around to see if you can get a chip to raise you e computer's rev limit up to 6500 or so. Markd has made a few of them. Other choices are to convert to 1.3 like it explains at the beginning of this thread, or go standalone
                    Old and improved:
                    • jmc1590
                      • Jul 2008
                      • 112
                      #115
                      Or he doesn't have the 173 ECU that he thinks he does. Before getting another chip, I would verify which ECU is being used. (Could even be a 154 unit from a Super Eta, which would explain the 5500 rpm limit.)
                      • E30Kaiser
                        • Mar 2008
                        • 1790
                        #116
                        Well I looked a couple days ago to make sure because that was the first thing that came to mind, because I was given a 173 in a box of parts with the car too. A 173 is in the car though. Are there different 173's? If so I am just going to throw that other one in there and see what happens.
                        • jmc1590
                          • Jul 2008
                          • 112
                          #117
                          No, all of the 173 ECU's are the same. However, there are different chips available from numerous sources, some better than others. Since you have an extra ECU (173), I would try swapping that first. (I'd be interested to know what chip # is in the 173 box with the 5500 rpm rev limit.)
                          It's possible, unlikely, but possible that someone sold a Motronic 1.1 box with a "173" cover. (Same connectors, different programming.) If so, I would think that your 2.7"i" would be running poorly with the "i" cam.
                          Just my .02
                          • kenika65
                            • Aug 2007
                            • 1336
                            #118
                            What tach does your car have? 7000?
                            • E30Kaiser
                              • Mar 2008
                              • 1790
                              #119
                              yeah....but the limiter cuts in around 5500 as I said.
                              • kenika65
                                • Aug 2007
                                • 1336
                                #120
                                Time to swap in a different 173ecu...
