Should I replace my head gasket while my engine is out?
  • Joey Link
    drunkest guy at Oktoberfest!
    • Nov 2004
    • 1176
    1989 325i w/129,000 miles. Seemed fine when I pulled the engine, head gasket kit costs around $47 (cheap). I've heard if cars don't need the head gasket replaced it's best to keep the original, since the seal is tighter or something, but I don't know if it's true. What do you guys think?
    • 34847
    if there's nothing wrong with it, leave it alone. you'd be opening a can of worms - you really need to have the block and head surfaced and checked for flatness, there's a bunch of other gaskets you'd want to replace on top of the head, you have to get new headbolts and then you have to torque them properly. and then if you have the head off, you may as well refresh it.. and on and on and on, until you've spend $1500 instead of the $47 you'd planned. :)
    • Joey Link
      • Nov 2004
      • 1176
      Thanks man, that's what I figured. The head gasket is the only external gasket that isn't going to be replaced.
      Side note: anyone know what size the torx bolt is that holds the cam gear?
        • 34847
        t50 I think - m10x35
        • Joey Link
          • Nov 2004
          • 1176
          Killer, I'm heading to Sears. I gotta get this cabby running, it's been down for SO long. Thanks again.
          • rcko
            • Mar 2007
            • 295
            agree with nando....
            "if there's nothing wrong with it, leave it alone" inspect it all out make sure its all good, line timing belt, water pump etc.
            - 0.05s and 0.1s FTW!!!
            • kenika65
              • Aug 2007
              • 1336
              The only reason I would take the head off is to port and polish the head. So unless you have a compression leak then leave it on. If you do have a compression leak (do a leak down test) then id suggest new bearings and rings. I prefer to do it right the first time.
              1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
              1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
              • Joey Link
                • Nov 2004
                • 1176
                Is there a way to do a leakdown test with the engine out of the car? You have to turn it over, don't you?
                • kenika65
                  • Aug 2007
                  • 1336
                  Nope just have to have the leak down tool and you have to close the valves by backing off the rocker arms.
