no pressure
  • kamotors
    • Nov 2007
    • 7102
    no pressure
    my car runs fine...but i think its running a little rich(leaky fuel injectors or bad coolant temp sensor)...when i went to change my fuel injectors, i started the car , turned it around then shut it off. I pulled the fuel line on intake side(right side) of the FPR and was expecting gas to pour out but there was only a small drop.....is this normal?
    7speedshop.com
    • 34839
    did you hook the FPR up backwards? (return and pressure lines reversed)
    I did that once - betcha that's what happened to you as well. it's easy to swap them so I'd give it a shot..
    • kamotors
      • Nov 2007
      • 7102
      ive never removed the fpr
      7speedshop.com
        No pressure at the fuel rail right after shutting off the engine means either a bad FPR or a bad check valve in the fuel pump. If the FPR is at fault you won't have normal pressure in the fuel rail while the engine is running. The fuel system checks in the Bentley manual should help pin down what problem(s) you have.
        • kamotors
          • Nov 2007
          • 7102
          where could i purchase the check valve? could it be leaky fuel injectors...i used to have hard warm starts but latley my car hasn't had any problems
          7speedshop.com
            • 34839
            but you had to of removed the fuel rail to change the injectors.. so did you take the fuel hoses off? if not then ignore what I said above :p
            • kamotors
              • Nov 2007
              • 7102
              I never changed the injectors because i had to remove the valve cover but ran out of light so i gave up and put it back together. i only removed one fuel line
              7speedshop.com
              • rcko
                • Mar 2007
                • 295
                fuel pump ck valve. do a quick search. the fix is an auxiliary ck valve about $10 from the dealer. ck the previous post through the search and you should find the part number
                - 0.05s and 0.1s FTW!!!
