anything i need more???
-Eta bottom end
-Super ETA pistons
-new chromoly piston rings
-885 head
-i cam
-double valve springs (it should come with all this if you buy used)
-motronic 1.3
-87' i wiring harness
-i AFM
-i intake boot with idle control valve
-i throttle body
-i intake manifold
you can use the stock exhaust manifold, the exhaust ports are almost identical in size
-i front dampner (you need this for the crank position sensor that goes there
-i crank position sensor (this deletes the need for your sensors that come off of the bellhousing)
-m50 injectors or better (I have 24lb ones, a cartech RRFPR, and a wideband o2 sensor so I can adjust the fuel pressure and get it running perfect.)
-3 bar fuel pressure regulator
what else ??? also i heared the 'i head in combination with
the 'e pistons drops the compression so low that even running is a
problem. so what should i do, chip the fucking car and get better gears ratio, i have 2.9LSD. what should i get ,and some people told me adding a chip to the eta motor will cause the singe valve springs to float??.
iam so confused. also if i did the 2.7i conversion what should i end up with ??how much HP's and torque.
-Eta bottom end
-Super ETA pistons
-885 head
-i cam
-motronic 1.3
-i AFM
-i throttle body
-i intake manifold
