Idle issue???
  • 8oost0ne
    • Apr 2005
    • 431
    Idle issue???
    I just installed an adjustable fpr today and after the installation the car seems to have a high idle (running 50lbs of fuel), does anyone have any suggestions? My car has the 2.5 with 173 dme, m30 afm, 17# injectors, port matched, polished, and decked head (with a thin headgasket), hollowed out exhaust manifolds, magnaflow cat, muffler, and 2.5 inch exhaust.
  • kenika65
    • Aug 2007
    • 1336
    You mentioned that you have a stock 173ecu in on your 2.5. I would suggest getting a tunable ecu. Like the MMS, MS, MS2 so that you can control your fuel and spark. You are giving your engine a lot more fuel and air then your computer thinks.
    http://millerperformancecars.com/catalogue/index.php
    1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
    1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
    • 8oost0ne
      • Apr 2005
      • 431
      Thanks, I figured it out... all I had to do is unplug the vacum line that went to the stock fpr.
        • 34844
        you need that vaccum line - it's to keep the FP constant during all engine loads. without it the engine will probably run lean (or really rich) at WOT.
        • 8oost0ne
          • Apr 2005
          • 431
          I just actually plugged it up... I disconected my dme overnight and it seems to idle correctly now...
