2.7i, shaving i pistons?
  • E30godz
    • 1524
    Does anyone know any specs on how much shaving on an i piston is needed to achieve a head-clearing height/decent compression. The more info the better. It seems like i've heard '3mm' before.
  • ColdAccord
    • 5926
    i dont know but I have a set of brand new Mahle 10.2:1 pistons for a stroker. $500, comes with rings, and I'll even throw in the set of "i" rods for free. all you need is a 2.7 crank and an "i" head and it's good to go. or I also have an "i" crank I'd sell for $60 along with it
    Originally posted by blunt
    • E30godz
      • 1524
      thats a good deal, but its probably a little out of my budget. Are they for 1mm bore over or stock bore?
      • ColdAccord
        • 5926
        stock bore
        • h82crash
          • 127
          Anyone with an answer to this one? I curious too.
          "Life is hard...it's a lot harder if you're stupid."
          Tom
          72 2002
          87 327i
          88 525i
          88 535i
          03 530i
          • digger
            • Nov 2005
            • 6176
            if you use eta crank, I rod and I piston then 3mm is the nominal amount to remove. If you use the same but E rod you need 2mm extra. Its a waste of time machining the pistons IMO. Find your self a single vanos M52b28 crank, E rods and I pistons and your good to go.
            • Madhatter
              • Oct 2004
              • 966
              ive said it before when i actually measured a set of pistons and worked out the math. The 3mm is a load of bollocks, you need to reduce compression height by 3mm, however that figure doesnt factor in the 4.43mm crown sitting above the piston too. If you shave 3mm off your pistons what you end up with is most of the crown gone and a piston still sitting above the block.
              A lot of guys dont like e30tech, but im going to link it anyway. http://www.e30tech.com/forum/showthread.php?t=11729
              Just a little project im working on
              - http://www.lse30.com -
