Another 2.7i question
  • SamE30e
    • Sep 2007
    • 4319
    Alright,
    I got a i top end for free, everything.
    When I swap it on, can I use the factory eta harness inside the car and just swap plug the engine harness into the C101 connector? Or do I need the whole harness from the i?
    Last question, if I put a chip for an i engine on the 2.7i swap will it work or will it just mess everything up?
    Thanks
    Sam.
    1985 325e 2.8 Turbo VEMS
  • kenika65
    • Aug 2007
    • 1336
    Click on my links and read carefully. http://www.r3vlimited.com/board/showthread.php?t=100939 Here is a link
    http://www.e30tech.com/forum/showthread.php?t=39960 This one has pictures.
    Yes you need the i harness, the injector rails are different and the sensors are different you also need the i harness so you can plug the 1.3 #173ecm in an with a chip you can rev 7000+.
    On second thought you have a 87 so can you tell me if you have a CPS or reference sensors on your bellhousing? You might allready have 1.1 harness and all you will need is the 1.3 173ecu and plug it in.
    1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
    1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
    • SamE30e
      • Sep 2007
      • 4319
      I have 2 sensors on my bellhousing.
      Are you refering to the timing reference sensor?
      So you're saying all I would need is the head with all the little bits like injectors, idle control system and I can use my harness I have now.
      Thanks
      Sam
      • kenika65
        • Aug 2007
        • 1336
        Because you have the two sensors on your bellhousing you are going to need the total 1.1/1.3 harness which has the crank sensor on the front near the harmonic balancer.
        • SamE30e
          • Sep 2007
          • 4319
          Oh, I have that sensor on my harmonic balancer too.
          • kenika65
            • Aug 2007
            • 1336
            lol sorry if I am no help because I dont have a 87 i have a 86,89,91 so.. well let me know the last three numbers on your ecu in your glove box then I will know for sure.
