Broken Rocker
  • Kate325is
    • Mar 2008
    • 53
    Broken Rocker
    So the car I just bought has a broken rocker, any advice for what I should do? Can I replace just the broken one or is this going to require a head rebuild like I had to do on my 525 a few months ago?
    Thanks!
    Kate
  • ieatpeople
    • Mar 2008
    • 883
    you should be able to just replace it, but there is probably a reason it broke. hopefully there is no other problem.
    if you do replace it, don't forget to adjust the valve lash before starting the car.
    Originally posted by BillBrasky
    That's like Vlad challenging Chip Foose to a car painting contest.
    Originally posted by acolella76
    i'm pretty sure 'Phillis' is short for syphilis
    2007 CVPI, stock and slow
    1994 tercel, 5efhe swap, i/h/e
    1984 t-type, 5.3/th350 swap in progress
    My newest addition:
    Rebecca Arlene, born 4/19/2013
    • Kate325is
      • Mar 2008
      • 53
      The PO installed a MarkD chip and redlined it a lot I think, would that weaken it?
      • ieatpeople
        • Mar 2008
        • 883
        more rpm= more wear, but that is not the only way to break something, also check the valve springs to see if any are damaged. if the springs bound up suddenly at high rpm, it would overstress the rocker arms.
        My newest addition:
        • E30_fiend
          • Apr 2006
          • 7348
          True that.
          You should just check them thoroughly and all surrounding parts. You don't need to replace anything other than the rocker if everything else looks ok.
          Good luck
          E30Fiend
          • kenika65
            • Aug 2007
            • 1336
            Dont forget to check compression on that cylinder, because the valve might have made contact with the piston.
            So how much you pay for your new car.
            1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
            1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
            • NC325iC
              • Mar 2004
              • 6565
              i think if you take the valve cover off and spray some silver paint in there itll be fine
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                Werd. This man knows his e30's.
                • Jparkr
                  HR Admin
                  • Jan 2006
                  • 3494
                  He knows cars in general. I spray painted my timing belt last night. Thanks to his advise I should be good for another 60k now.
                  1987 PRO-3 car /1990 325is (2.7i Concours)
                  • E30_fiend
                    • Apr 2006
                    • 7348
                    :rofl:
                    E30Fiend
                    • bwanac
                      • 3354
                      Originally posted by abigballafb76
                      :rofl:
                      E30Fiend
                      why do you sign everything "e30fiend" that is not even your username?
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        I don't think you would have valve to piston contact if you broke a rocker arm. When the rocker would break, the valve would instantly close and stay closed. For the piston to hit the valve, the valve needs to stay open when it isn't supposed to be open.
                        • Sean
                          • 5793
                          Just start doing your girlfriend on the hood. And get pictures.
                          Then your rocker will magically be fixed.
                          Send me pics, and I'll MAKE SURE it gets fixed!
                          - Sean Hayes
                          • bostonbmw
                            • Nov 2004
                            • 429
                            I had the same problem on my e30 the #3 rocker arm on the intake side broke. I would replace all the Rocker arms on that side not just the one that broke. If you have a broken rocker arm on the intake side you DO NOT need to pull the cylinder head to replace it.I am not sure about the exhaust side but on the intake side just tap the rocker shaft out through the cam gear (See photo)
                            Latest news coverage, email, free stock quotes, live scores and video are just the beginning. Discover more every day at Yahoo!
                            • e30s52
                              • Oct 2007
                              • 5235
                              its easyer to get at it if the head is off. i would replace them all and beef the cam while you are at it.
                              www.gutenparts.com
