Clutch Questions
  • blitzed310
    • Sep 2007
    • 41
    Clutch Questions
    I'm replacing the flywheel & clutch in my E21 (M10). I got the 323i 228mm flywheel cleaned and resurfaced. So now I need to choose a clutch. I just want to verify that the throw out bearing that comes with a stock M20B25 SACHS kit will be what I need. Or if I will need to piece this kit together?
    Is there a difference in throw-out bearings for an M20B23 to a M20B25?
    I am a little confused, using BavAuto's site there are 2 part #'s for the throw out bearing.
    For an E21 323i it list:
    Part # 21 51 1 223 366 $34.95
    Part # 21 51 1 204 525 $57.95
    For an E30 325i it list:
    • 37833
    I think you're going to want to use the 323i unit. There's also a 5 series one that will work, that's what I have in both of my cars. A bit beefier. Can't remember which car it's from exactly though. Search James Crivellone, I have the same one he is running.
    Grover Beach, California
    BimmerHeads.com
    • markseven
      • Sep 2006
      • 5327
      Is the beefier TO bearing for the added power from the turbo?
      I Timothy 2:1-2
