lambda
  • kamotors
    • Nov 2007
    • 7102
    lambda
    my cars reading fault code 1222. which is the Lambda control 1? what is a Lambda. I just installed new brakes then did a stomp code thing. i ran seafoam about 2 weeks ago, could that of caused this? the car runs fine...i think. where is the lambda located?
    7speedshop.com
    • 34847
    it's a check code for the O2 sensor - I can't remember which is which, but one code means the O2 values are out of range, and there is another code that means the O2 sensor isn't working.
    • kamotors
      • Nov 2007
      • 7102
      so i need a new O2 sensor, mines only about a year old. what are O2 values?
      7speedshop.com
      • kamotors
        • Nov 2007
        • 7102
        so i checked for leaks and couldn't find anything. my 0-60's have been slower. cant seafoam mess up an o2 sensor. my car seems to idle fine. but the power seems a ltitle down. should i get a new o2 sensor or use some fuel system cleaner like bg44k
        7speedshop.com
        • EtaSport
          • 2853
          Lambda control is usually emissions related, it is because the sensor can no longer adjust to keep the engine at stoich.
          Old and improved:
          • kamotors
            • Nov 2007
            • 7102
            all fixed and my 0-60 is magically 2 seconds faster. makes no sense
            7speedshop.com
            • EtaSport
              • 2853
              Did you clear the code, or do anything, or did it just start running right?
              Old and improved:
              • kamotors
                • Nov 2007
                • 7102
                undid the battery, then let the chip relearn and all is now good, and by 2 seconds faster i mean now its going normal, earlier it was 2 seconds too slow
                7speedshop.com
                • EtaSport
                  • 2853
                  Yea, it was probably a code from the seafoam, and it will tend to make the car run poor until it is cleared.
                  Old and improved:
