Coolant hose issues.
  • ryant
    • Feb 2007
    • 25
    So while driving home from the store my coolant level check light comes on. I pulled over popped the hood to discover that the top coolant hose had popped off, clamp was loose. So i put it back on and tightened it up and drove it the few blocks back to the house, engine temp was fine. Coolant got all over the engine bay, should I rinse the engine bay out with some water? Also, do I need to bleed the system or anything, or is refilling the expansion tank fine?
  • kenika65
    • Aug 2007
    • 1336
    Yes bleed the cooling system and replace any worn out clamps to prevent this in the future, if your going to spray your engine off then spray it when it is running.
    1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
    1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
