Car starts Hits 1k rpm and dies...I did search
  • Burnall4
    • 145
    So i just rebuilt my engine put it back in everything plugged back up and then I go to start the car and it starts up for 2 secs hits about 1000 rpm and dies...
    here is what I have checked
    Idle control bypass valve
    MAF
    Fuel Pressure
    Timing
    etc...
    Anythoughts?
    Burn
  • Burnall4
    • 145
    So here is what I have figured out...
    1. I put the car back down on all 4 wheels/tires
    2. Started it one last time
    3. It ran, but sounded like SHIT
    4. Checked the spark plug/wires/etc...
    5. Noticed the MAF plug was not plugged in
    6. Plugged the MAF sensor back in
    7. Car cuts off instantanously
    So I am making an assumption that it is the MAF that has gone bad?
    • dark89e30
      • 263
      throttle position switch bad/ not adjusted properly?
      • Burnall4
        • 145
        could the timing have anything to do with it? it backfires when i leave the MAF unplugged and let it idle, i mean the car makes a poping noise, the engine shakes, and sounds like crap...?
        • jmc1590
          • Jul 2008
          • 112
          Timing is complete controlled by the ECU and therefore non-adjustable. I assume you mean AFM not MAF. The start and dies sounds like a similar problem when I forgot to connect my AFM after working on the alternator. Perhaps "resetting" the ECU by disconnecting the battery for a few minutes.
          If indeed you do have a MAF, please extrapolate on what other changes you have done.
          • Burnall4
            • 145
            Sorry I have an AFM, not a MAF (force of habit)
            My ICV is constantly buzzing is it suppose to be doing that?
            • Burnall4
              • 145
              Well I got a friend's spare 325i ECU and tried that and it did the same thing....
              • jmc1590
                • Jul 2008
                • 112
                Vacuum leak(s)? Also check from the AFM to the throttle body to make sure you're not drawing in unmetered air. (Torn intake boot, disconnected idle air line...)
                • Jon325i
                  • 6934
                  Does your friend have a spare AFM? If he does you might want to swap it with yours and see if things improve. I've had two AFMs fail on me before and the symptoms were similar to yours.....either just engine stall or run very very poorly. Sometimes the fix is just a matter of cleaning up internal passages since all kinds of neat gunk can build up in there - others times they just fail altogether and you go find a replacement. Should you elect to try the cleaning approach first, use CRC brand MAF cleaner (Kragen and AutoZone carry it).
                  Jon
                  Rides...
                  1991 325i - sold :(
                  2004 2WD Frontier King Cab
                  RIP #17 Jules Bianchi
                  • DCColegrove
                    • 2748
                    Is the MIL (check engine light) on?
                    • Burnall4
                      • 145
                      no :???:
                      • dark89e30
                        • 263
                        Throw it in the trash, and good things will happen
                        • Burnall4
                          • 145
                          After all this time I have finally figured it out...it was the timing, electrical....now to fix it....FAWK!
                          • SpecM
                            • Oct 2005
                            • 4531
                            -what was the problem? CPS?
                            1989 cirrisblau-metallic 325i
                            • Burnall4
                              • 145
                              yeah was the CPS and it was the throttle position switch along with the ICV, the ICV was buzzing so bad bec the TPS wasn't working...(i am assuming on that end) but i switched it for a known working combo, fired right up, "shrugs" even the valve ticking is gone...haha I will know more after I pull the engine out again. I am going to re-do the timing belt and re route some of the wires. It looks like the CPS was running behind the pulley, it was almost down to the copper (went through the black shrink wrap and the coating on the wire itself). Mind you, it was not like this before so it was my mistake when putting it back together...i will keep you guys updated!
