Oil in intake boot... ?
  • bimmerboy12
    • Jun 2004
    • 1057
    Took my intake boot off, and found some motor oil in the corrugated ridges, and a little in the opening of the MAF. What does this mean? Please dont say its oil pushing past my valve seats... the car runs great and pulls hard.
    Thanks!
    Brian
    1988 325iC Project - FINISHED!
    Build Thread: http://www.r3vlimited.com/board/show...ht=325iC+paint
    • 34839
    a small amount is normal, if it's enough to drain through the AFM and into your air filter, then I would worry.
    • kamotors
      • Nov 2007
      • 7102
      it's normal as said above
      7speedshop.com
      • ADEN
        • 620
        i have the same problem my TPS is oily i need to clean my intake due to idle problem,before that i have to install an oil catch to prevent this to happen in the future and lessen my HP. lol
          There are two possible causes for oil in the intake. One is worn valve seals and the other is worn rings. A compression and leakdown test will usually reveal which is the most likely.
          • mikegar
            • Aug 2005
            • 523
            there is that crank case vent that vents right right into the intake. it could be coming form there.
            Originally posted by Ferdinand
            I carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
            DIVING BOARD DIVISION DIVISION IDIOT
