well i just adjusted the valves on my 1990 325ic since there was a slight tick.....well it started good i was adjusting one at a time stpped in between to cheack my work well at least on cyl 1 started fine tried to listen for other ticks found 1 more after checking all the valves again i tried to start it it did but was not responding to the gas pedal only rough idle then it cut its self out tried again nothing....now everything i took off is back correctly im dumbfounded to what this could be......someone please help thank you
valve adjustment and now no run......
well i found out that i guess my timing jumped some due to a loose belt .....(recently had the head done) so now i got it all timed to tdc but i am now wondering if i am on the wrong stroke since it hesitates to run now.....almost kicks over but then keeps trying to turn over....
All wires and hoses are hooked up correctly definately any ideas is greatly appreciatedCars I own:
325ic '91
Originally posted by classiccarsrule85 View Postwell i found out that i guess my timing jumped some due to a loose belt .....(recently had the head done) so now i got it all timed to tdc but i am now wondering if i am on the wrong stroke since it hesitates to run now.....almost kicks over but then keeps trying to turn over....
All wires and hoses are hooked up correctly definitely any ideas is greatly appreciated
Its too late now but I am curious as to what spec where you adjusting your valves too?
And also on a M20 the valves are supposed to tick slightly, its a mechanical cam.Last edited by peerless; 09-18-2008, 11:46 PM.
.010 is called for doing such a thing as this when cold i know that haynes calls for .012 either hot or cold but ive researched other books and i know its always best to do cold....
And now I didnt do the head job a part time mechanic did someoen my great uncle trusts with all his cars(being as hes a car dealer)
And valves are not bent checked for compression and everything is ok though before this happened i do know there was a slight compression leak probaly from the rings slowly going.
But yea ever since that head job its been getting progressivly worse and i thought i might as well check the timing while im at it. I do know how to properly do a head job ive done many on honda civics as well as my old 635 but my mom didnt think i could handle it.....yay great confidence buster there but now its looking like i have to do it no matter what unless she decides just to sell the car as is i mean we just put in at least 1k into her not counting the head gasket replacment.........
but is it possible to be on the wrong stroke? if so i might as well try itCars I own:
325ic '91
well ummm this is going to make me sound dumb now but i just rechecked timing and well what i thought was off is on correctly lets just say i did not rotate the crank 1 more time so that the cam matched up with its mark.....this just makes me feel stupid yet more curious to what could be wrong i know ive already done the crank position sensor on this car before it was a bitch.....i hate them dearly as well....but im beginning to think that it might really be the problem again......but yea any suggestions? since timing is not an issue im going to wait till either my mother or one of my friends is free so i can make sure its getting spark because i know its getting fuelCars I own:
325ic '91
