What Head Gasket do i get?
  • B2702
    • Jun 2008
    • 293
    Hey fellas
    Which head gasket should i get for my 2.7 stroker motor?, the following parts have been used for the conversion:
    885 (325i) worked head
    High compression pistons
    2.7 block
    Can i use a 731 head gasket or would it be different? if its different, then do i get a 325i head gasket or a 325e gasket?
    you help would be very much appreciated.
    Thanks
  • Dyno4mance
    • 345
    I would also like to know what is considered to be the head gasket to use on this configuration.....I know Metric Mechanic do a re-worked gasket with improved coolant passages, has anyone used their gasket and have feedback on its performance?
    IE also do a motorsport/competition HG for $200.00....anyone know what that is?
    B2702...What compression pistons are you using?
    2.7L M20 11:1 COMP 195 whp Dyno Dynamics 2380lbs
    • digger
      • Nov 2005
      • 6163
      Just use a 325i gasket (its probably the same as 325e one) but 731 gaskets come from a block which is 80mm bore not 84mm like the 325i and 325e.
      • B2702
        • Jun 2008
        • 293
        Thanks Digger, also a quick question
        If a car has a blown head gasket, will the car be able to start and drive?
        cheers
        • Kingb
          • 928
          I have a blown HG and I was driving it for about a week before I saw the coolant and oil mixing and I still have to drive it about 8 miles to my shop. That is the last time until it is fixed
          Originally posted by Nicademus
          My car beats off to that car. :bow:
          • B2702
            • Jun 2008
            • 293
            But like does the car cut out and run really rough and vibrates alot or nah?
            • Kingb
              • 928
              no just gets hot really fast. It actually still runs the same and still has power but I stay out of that for now
