Sweaty, bloody, dirty.... and still no idle.
  • MIKe30
    • Sep 2006
    • 2334
    I've swapped a running m20 into my 318is since my m42 took a crap on me. The m20 is from my alpine 325is that is going 24v. The only thing wrong with the motor was a vacuum leak and a leaky oil pan gasket. Oil pan gasket was fixed, and the vacuum leak never caused any real issues while in the alpine car, but waiting on intake manifold gaskets in the mail, nonetheless.
    Fast foward to now. M20 is in the 318. It starts and runs as long as i continue blipping/feathering/revving the throttle. If I let drop back down to idle, it runs rough and shuts off. When I take it for a spin, at about 2.5k-3k under load it boggs down and cuts off... if I feather the throttle it comes back to life. In neutral, or if the wheels are spinning (on snow) I can rev up and down the range no problem. Under load, 2.5k-3k cuts off.
    I've changed the ICV/intake boot. I've swapped the air flow meter. I've cleaned the spark plugs. I've replaced the spark plugs. I've swapped the fuel pressure regulater (got sprayed in my eye with gas, that felt good). I've swapped the fuel filter. Tomorrow I'm going to try fuel pump unless somebody can f'ing save me from wasting more time.
    Havent had any luck finding this, but if somebody has an early 90 325is and wouldn't mind going over what hoses go where (maybe over the phone?), I'd greatly appreciate it. I may have possibly gotten a vacuum hose placed backwards or incorrectly somewhere.
    Any help is greatly appreciated, hopefully someone has encountered similar issues.
    -mike
  • ethirdy
    • Nov 2007
    • 406
    Same problem. Runs great cold, no load. Warms up, stalls under load.
    Parts replaced:
    AFM
    3 relays (main/fuel/?)
    Spark plug wires
    ECM
    TPS/throttle body
    Oxygen sensor
    Fuel pump (was replaced recently by PO)
    Fuel filter (was replaced recently by PO)
    Spark plugs (PO recent)
    Tomorrow:
    CPS
    spark plugs (swap current platinums for Bosch Supers)
    Clogged cat - will cut out/straight pipe
    fuel filter (again)
    coolant temp sensor
    thermostat
    uhhh....?
    This one floors me. I've worked on 20+ different e30's, almost all of them m20's, and I have no idea what's going on. Shit, I've replaced just about everything - what am I missing??
    Originally posted by alpinaclone
    Since the real economy is in the shitter, I say we start our own.
    This is how it works; you buy my junk, then I will buy more junk and so on so forth etc. etc. Think of the future of your children and buy my stuff.
    • E30_fiend
      • Apr 2006
      • 7348
      The one thing I didn't see on your lists were the fuel supply and return lines. Common problem really. It will solve a few problems. Running rich/lean and fuel cutting out. You can change the fuel filter all you want but if you have clogged fuel lines then changing the filter won't to any good. Check that put and report back
      Taylor
      • ethirdy
        • Nov 2007
        • 406
        Buuuut - why only when warm?
          • 34844
          if it changes warm vs cold I would be looking at the coolant sensor very first, the only other thing that is temp dependent is the O2 sensor.
          • Naplm00
            • Nov 2008
            • 1573
            shot in the dark
            tried swapping ECUs?
            88 325ic ~~~> Rusty and ugly
            85 E ~~~> RIP
            • BMWZ318is
              • Nov 2008
              • 102
              sounds like a vacume leak to me i hade one and my car did the same thing my check engine light was on tho but let it run then pull the plugs to see if its running to rich or to lean do you have an aftermarket fuel pressure regulator on there
              • ethirdy
                • Nov 2007
                • 406
                Originally posted by Naplm00
                shot in the dark
                # 3 on list # 1 - no change whatsoever.
                My CEL comes on and off - always an 0A code (lambda emissions)
                It's running rich - plugs are brand new, FPR is stock from known good vehicle.
                Running out of ideas here...
                • BMWZ318is
                  • Nov 2008
                  • 102
                  it could be floding itself out you might have leaky injectors
                  • MIKe30
                    • Sep 2006
                    • 2334
                    shot in the dark
                    Nope. But this m20 was in my sig car that I drove to my house before I took it out. There was no problems on the way over.
                    stock fpr. even swapped it with another stock fpr. no change.
                    Seriously, get your own thread. With you in here I cant distinguish who is trying to help who. If you have your own thread, stick to it. If you don't, then start a new one.
                      • 34844
                      • MIKe30
                        • Sep 2006
                        • 2334
                        what happens if you overfill a system with too much coolant?
                          • 34844
                          nothing, it just comes out of the overflow line from the resivior.
                          • MIKe30
                            • Sep 2006
                            • 2334
                            yea, i realized that was a stupid question after i posted it. although, now that you meantion it, i dont remember ever seeing an overflow provision on the m42 rad that i'm running.
                            Anyway, i'm taking the intake mani off now. its a pain in the ass.
                            • ethirdy
                              • Nov 2007
                              • 406
                              Whoa buddy, we've got the same problem - so answers work for both of us. I know it's frustrating to try and troubleshoot, but it's not like I'm threadjacking talking about euro ellips or something. I posted over here because maybe some of the things I did/thought of would help you.
                              My problem was the fuel pump sucked up too much crap on the bottom of the tank and burned out - replaced pump, all good. Hope it helps...sorry for butting in :(
