location of the cps?
  • menusk
    • 96
    where is the location of the cps? i have an 87 325i. im getting fuel but no spark and i want to test this but not sure which one it is. thanks
  • DCColegrove
    • 2748
    Front cover, right (passengers) side, at the crank pulley.
    • Schneider325
      • May 2004
      • 3818
      I'm pretty sure your CPS needs to work for you to be getting fuel. The CPS sends a signal to the DME, then you get fuel! The CPS is located right off of the crank flywheel, on the right side of the engine. The wire connects right underneath the diagnostic port
      • ForcedFirebird
        • Feb 2007
        • 8300
        Sorry about the off-topic q, but how many notches are on the CPS?
        john@m20guru.com
        Links:
        • menusk
          • 96
          thanks, if this is true then i need to go another route........i pulled out my spark plug and laid it on the valve cover and no spark when i cranked it....and the only reason i know im getting fuel is because i can hear it come on and it started dripping fuel from the boot that hooks up to the air filter(from so much cranking the engine)...this is probably bad hehehe...is there a way to test the coil . i put my ohm meter leads on the positive and negative sides of the coil and only getting 3 volts from there when cranking..any other way to check it?
            If the fuel pump is running when the engine is cranking over and firing pulses are present at the injectors, the problem isn't the CPS. Neither of those will be present if the DME isn't powered up or the CPS is bad. Just no spark under those conditions is, a bad coil, wiring fault, or bad DME. The positive side of the coil on this car is powered by the main relay and the negative side is grounded by the DME for each each spark pulse. Check from positive to ground for 12v with ignition on. Use a scope or test light on the negative side to look for firing pulses.
              • 34844
              60-2 (58 teeth total with 2 missing).
              your GM ecu is probably looking for a 36-1 wheel.
              • thereisnoyun
                • Feb 2007
                • 2301
                you dont need to know were to CPS is to test it. Get an Ohm meter, unplug it right under the circular obd1 code plug next to your icv. its the one closer to the driver side fendr. you should have resistence from 1stt and second prong around 540+/- 50ish. If not then replace. Easy test, and then test your coil pack primary should be .5 secondary should be 5000. You can narrow your search all day long, but testing it with a ohm meeter takes 10 min.
                • menusk
                  • 96
                  thanks for the info everyone. i just ended up changing the car computer and it started right up. i tested everything possible and everything checked out. finally i said f it and changed the computer and it finally worked. thanks for the help everyone
