anyone have any input on using the early euro eta pistons with the 885 head? it will give a greater compression ratio than any of the other oem m20 pistons but im concerned about the shape not being optimum in relation to the 885s combustion chamber. any opinions would be welcomed thanks. and heres the piston specs:
11:1 eta pistons
no one besides rs4pro3 knows anything about these pistons? and yes ive searched!
moore questions if someone does know something: was there a different euro-spec eta head for the high compression pistons? does anyone know stock eta cam lift in mm? come on guys ive got grand plans for these:D -
I am using themanyone have any input on using the early euro eta pistons with the 885 head? it will give a greater compression ratio than any of the other oem m20 pistons but im concerned about the shape not being optimum in relation to the 885s combustion chamber. any opinions would be welcomed thanks. and heres the piston specs:
http://www.bmwccn.no/rogaland/Mahle_m20.html
The shape of the tops does not seem to have caused any problems...i have been using them for for the last 18 months. Engine runs great.
I am using a stock 325i cam and there was plenty of clearance between the valves and piston tops
that is great to know man! just the kinda answer i was looking for. im also thinking about using a ported eta or 731 casting head to get full compression and match the pistons better, but im concerned about the clearance there when im no longer using an eta cam. know of anyone running that setup - these pistons with eta head?Comment
Was searching and found this? any more info from anyone, looking for high compression options for my 2.7 witrh i cam and computer or a future m20b25. What are my options?97 tacoma 5 spd 4 cylinder
2001 330ci 5 speed
83 733i 5 speed, (FS)Comment
Also where can i buy those euro pistons?97 tacoma 5 spd 4 cylinder
2001 330ci 5 speed
i had a set of mahle 10.2:1's meant for 325i head & 2.7 crank & rods. they were used by racing dynamics for their buildsOriginally posted by bluntcan you get me a deal on cases of their (fiji) bottled water? i wash my 02 in that shitComment
i sold them to someone on here for around 550. don't remember whoOriginally posted by bluntcan you get me a deal on cases of their (fiji) bottled water? i wash my 02 in that shitComment
anyone know where to buy euro pistons?97 tacoma 5 spd 4 cylinder
2001 330ci 5 speed
I got mine from ebay.de
some of the german guys are not too keen on paypal however so check with them first. Also don't worry about the language difference as most of them speak better english that you will find on these forums :D
