throttle body question
  • jkl
    • 53
    I got 1986 325es
    Old throttle body is bad,but I got an extra one it is of 1988 325i
    is it gonna work on my car ?
    I'm new guy and rebuild my first car...
    thanks
    Русский
  • SpecM
    • Oct 2005
    • 4531
    Not sure if an "i" TB will fit an "e" manifold, but the "i" TB and manifold will fit an "e" head
    if that helps any...
    1989 cirrisblau-metallic 325i
    • Liam
      • 753
      The "i" is a larger bore, different heater and breather tube configuration and the studs may not fit either (not sure on the stud pattern).
      I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
      • kenika65
        • Aug 2007
        • 1336
        You will have to run 1.3 Motronic to change to an i TB and intake.
        1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
        1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
        • triry
          • 10
          not quite,...........
          the eta was designed as a low rpm, torque happy motor, hence the small tb. a "i" tb WILL fit once the tb opening in the manifold is opened up to a diameter that allows the "i" throttle blade to open.
          its genuinely unlikely youll see any real performance improvement unless corresponding changes are made on the exhaust side of the motor,..............
