DME not powering up
  • malmeida1040
    • Oct 2017
    • 43
    DME not powering up
    I recently did a motronic 1.3 swap on my 86 eta. It always had a hard start when cold issue since did the swap. I began doing a once over on the usual stuff, vacuum leaks, fuel pressure test, coolant temp sensor. I couldn't figure it out and drove with the issue for a couple weeks. I was driving in traffic and the car died at a stop light, had it towed home. long story short the DME isn't powering up. I have power to the main relay and power at pin 27 and 18. When the relay is unplugged from the harness with the key is ACC I get a back feed of 5V on pin 86 of the main relay connector. I'm leaning toward a bad ECU but not sure.
  • Gregs///M
    • Mar 2012
    • 2459
    Check all related fuses and replace them. Also check the in-line fusible link which powers the DME direct from the battery. Those fuses and link gets old and can break from old age.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • tim88325is
      • Jul 2008
      • 201
      When mine failed the underside of the DME got really hot to the touch. If it is getting power for sure, I would slide it out and feel it...
      • malmeida1040
        • Oct 2017
        • 43
        UPDATE: so long story short when retrofitting the motronic 1.3 to an early model there is no ground on the shock tower like the late models. Since I had to improvise a ground, the ground I had choose was no good. I changed ground points for the engine harness and it fires up every-time no issues.
