Oil Filter Housing Assembly Banjo Bolt question
  • ziazhp
    • Nov 2015
    • 191
    I had an oil filter that was seized, so I had to remove the entire assembly. When I put the assembly back on, oil was leaking through the banjo bolt, as I damaged the crush washer. Does anyone know what size crush washer goes on that bolt? realoem doesn't show anything and I can't find a DIY anywhere. Seems like a common repair. Also, when removing and re-attaching an oil filter housing assembly, do I need to add new gaskets each time or only if there are damaged/old?
    '89 325ix
    '88 M6 Royal Blue
    '13 128i "M-Sport"
    '04 ZHP Mystic Blue-SOLD
    '02 E46 330xi-SOLD
    '89 325i Laachssilber metallic-SOLD
    '89 325i Bronzit-SOLD
  • digger
    • Nov 2005
    • 6215
    https://www.realoem.com/bmw/enUS/sho...diagId=11_4329
    item 5 pretty sure its the A27X32-AL so p/n 07119963441
    • uturn
      • Dec 2010
      • 1010
      Rubber parts harden/deform over time, go with new to prevent leaks.
      I would change the two o-rings. Item #2 & #4
      Pn 11421265670
      ​​​​​​Pn 11421714764
      Banjo bolt torque is 35-45 NM
      Scope creep-
      There's a kit(#7 pn 11429059338) for the oil cooler valve that comes with an o-ring. I'd change that out too as it'll eventually leak. Easy to change out while the housing assembly is off the block as you need to compress a spring to re-install the snap-ring.
