ETA is having an intermittent random starting issue.
  • 2mAn
    Señior Mod
    • 20825
    I believe its the fuel pump thats inside the tank, but thats just a blind guess...
    The issue: At completely random times (sometimes cold, sometimes warm) the car will take a longer time to start up. As I write this I wonder if its the cold start injector too.
    Is there something obvious I should start with ?
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
  • Gregs///M
    • Mar 2012
    • 2459
    If the car is above a certain temp, the cold start system will not be needed. I can understand if your car has a hard time starting only when cold, then this would indicate a cold start system. However, if your car is hard to start both hot and cold, then I would suspect a failing CPS sensor or AFM. If you have not replaced your engine ground cable, that can contribute to longer start crank times. A vacuum leak is also possible.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • 2mAn
      Señior Mod
      • 20825
      Thanks, thats a good start. I havent really paid complete attention to the details, but a few of those are easy to check to narrow down.
      Thanks again. I'll report back eventually haha
      Simon
      Current Cars:
      -1966 Lotus Elan
      -1986 German Car
