Engine "clacking" when warm
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5555
    So, I had refreshed my motor, new rings, rod bearings, valve job and some other things along the way.
    The engine runs fine, but after it warms up, the engine develops this clacking noise which is rpm dependent. The noise becomes audible after 2.5k rpm and is the loudest on deceleration at high RPM
    I took the engine apart again to inspect everything that was done and everything checks out.
    Sounds like piston slap, but what makes me not think that's the case is the sound is present only when warm...
    Any insight or experience with something like this?
  • ForcedFirebird
    • Feb 2007
    • 8300
    I had a car that did something like this. Turned out to be a loose rocker arm boss in the head. Slid the rocker shaft back, knurled the boss and slid it back. Far reach to be the problem you are having.
    Can you get us a sound clip?
    john@m20guru.com
    Links:
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5555
      Yeah, I'll get a clip right now.
      when you refer to the boss, are you just talking about the holes the shaft slides through or the actual shaft?
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5555
        Here's a vid of it.
        • digger
          • Nov 2005
          • 6128
          Seems like it is too high frequency to be valvetrain related.
          Crank hitting crank scraper ?
          • MrBurgundy
            R3V Degenerate
            • Mar 2012
            • 5555
            yeah, I was leaning towards that too..
            Especially since the noise almost subsides under load and off throttle it get crazy, so I'm thinking it was yet another shit INA tensioner. Gonna pull the cover off today and replace the tensioner and the spring.
            • MrBurgundy
              R3V Degenerate
              • Mar 2012
              • 5555
              Tensioner didn't help, the guy who did my head is coming over to hear it..
              • ForcedFirebird
                • Feb 2007
                • 8300
                I replied on my phone, must have never hit "post reply".
                Definitely sounds like valve train noise to me. I have often run the engine with the valve cover off to pinpoint issues like that. Just plug the crank case vent tube, and might want to put down something to collect the oil spatter.
                Some of the common issues:
                Loose rocker retainer
                Eccentric installed backwards
                Loose cam gear
                Loose tolerance on rocker shaft to head boss
                Rocker bushing out of tolerance (rockers "rocking" lol)
                john@m20guru.com
                Links:
                • MrBurgundy
                  R3V Degenerate
                  • Mar 2012
                  • 5555
                  Loose cam gear
                  So I isolated the noise to the exhaust rocker.
                  when I put the stethoscope on it, it's ticking ever time a rocker depresses and comes off the valve.
                  Pretty sure you're right forced, the shaft isn't sitting tight enough in the head.. I might just put a set screw in it.....
