m20b25 knocking, tapping, ticking? after valve adjustment
  • mnmnmmm_
    • May 2020
    • 29
    My m20b25 is tapping loud, both cold and warm
    I just replaced the valve cover gasket, 4 rubber plugs, did valve adjustment with 0.25mm feeler gauge (actually twice, just to make sure)
    I also replaced all 12 eccentrics since old ones were worn out
    I did clean valve cover since it was covered with oil and gunk inside
    I think it's coming from the head for sure
    It wasn't this bad before I worked on it, and now it's worse
    I read Bentley's manual multiple times and watched youtube videos on how to perform valve adjustments but still ended up like this
    Any help or comment or thoughts would be appreciated
  • ForcedFirebird
    • Feb 2007
    • 8300
    When adjusting rockers, make sure the lobe is pointing straight down and never try to do both rockers at once. Also, it's easy to locate the sound by running the engine with the valve cover off, just be sure to plug the vent hose, and might want to put something down to catch oil splatter.
    john@m20guru.com
    Links:
    • mnmnmmm_
      • May 2020
      • 29
      Thanks for the comment,
      I did make sure each lobe was facing down and the valve was closed
      I also adjusted them one by one
      I think at this point, it's out of my ability, maybe I should take it to a reputable bmw mechanic 🤦🏻‍♂️
      • ForcedFirebird
        • Feb 2007
        • 8300
        More than likely it's just a worn rocker retaining clip if the sound developed after the work. Also, it's possible to have the eccentrics in backwards. :/
        john@m20guru.com
        Links:
        • McGyver
          • 4636
          You might as well increase your ability by learning to fix this problem.
          I'm assuming the valve-train wasn't this loud before the adjustment, so you likely introduced a problem (which is a good thing). Follow FF's advice to see if it's a single valve or all of them. Adjusting valves is super easy, but adjusting them to a "slight drag" on the 0.025" feeler gauge takes some practice to get it right.
          You can do it, just try again.
          • mnmnmmm_
            • May 2020
            • 29
            by rocker retaining clamp, you mean P/N 11331280933?
            It looks like it's about a dollar each, easy to replace
            I'll try this for the last time, and double check the eccentrics and see how this goes
            Thanks for the help, appreciated!
            • mnmnmmm_
              • May 2020
              • 29
              I'm assuming the valve-train wasn't this loud before the adjustment, so you likely introduced a problem (which is a good thing). Follow FF's advice to see if it's a single valve or all of them. Adjusting valves is super easy, but adjusting them to a "slight drag" on the 0.025" feeler gauge take some practice to get it right.
              You're right, it wasn't as loud as this before
              It was ticking but not this loud
              Thanks for the comment, I'll try one last time replacing the rocker clamps
