Oil pan drain plug threads not flush
  • Hoffbrohaus
    • Sep 2013
    • 519
    Does this look right to you guys? Looks to me like a PO may have tapped and threaded the pan at one point and now they are coming out. Sent from my SAMSUNG-SM-G930A using Tapatalk
    '90 325is
  • roguetoaster
    Biggus Tippus
    • 7819
    Is that a threaded insert? Would be easy to tell with a magnet.
    • Hoffbrohaus
      • Sep 2013
      • 519
      It is magnetic. So someone put in a threaded insert? Anyone have tricks for getting it back in without a heliocoil? Sent from my SAMSUNG-SM-G930A using Tapatalk
      '90 325is
      • Hoffbrohaus
        • Sep 2013
        • 519
        I'll try a double nut on a bolt https://youtu.be/g9QRENi9-zI Sent from my SAMSUNG-SM-G930A using Tapatalk
        '90 325is
        • redlightpete
          • Mar 2012
          • 263
          That looks like a “timesert”. If you remove it, your stock drain plug will have nothing to thread into because the outer threads on the timesert are obviously larger. I suggest trying to tighten the drain plug into the insert, and see if the insert threads all the way into the pan.
