Car ran, Fuel Filter Replaced, But no Fuel going to filter now.
  • krose123
    • Oct 2020
    • 1
    Hello Everyone. Prior to the replacement of my fuel filter, my 1989 325i. started and ran. Key word ran. I took the fuse out, while the motor was running, let the car die and replaced the fuel filter. I put the fuse back in its place, went to start the car, and nothing for about 10 cranks. I disconnect one of the hoses from the fuel filter and then crank and no fuel is coming out of the filter regardless. Im lost as to how I should go about this as ive tried different fuses, fuel pump relays, etc. What confuses me is the pump worked prior to replacement of fuel filter, as I had previously mentioned that the car ran with the old filter. Could I have tightened the hose clamp too hard? Any input will help immensely. Thanks.
  • Vincenze
    • Apr 2019
    • 1046
    Filters are directional. Did you check the direction?
    Aren't any hoses pinched?
