Car will shift into reverse and only move some of the time.
  • ajfancypants
    • Oct 2020
    • 7
    I just recently did a 5 speed swap on my E30 and everything seems to work except sometimes when I shift it into reverse (the reverse lights come on so I know its in gear) and rev the engine the car does not move. Every other gear moves the car except for reverse. Any ideas?
  • 15Michaeljoseph
    • Aug 2013
    • 1693
    Was the transmission sourced from a car that reverse was known working? All new shifter linkage? Sent from my moto g(6) using Tapatalk
    (OO=[][]=OO) For Life
    • ajfancypants
      • Oct 2020
      • 7
      When I bought the transmission I was told that it was working fine, all new shifter bushings were put in.
      • ajfancypants
        • Oct 2020
        • 7
        I put the rear up on jackstands and I get get the wheels to spin backwards in reverse about 40% of the time.
        • Vincenze
          • Apr 2019
          • 1029
          Open the transmission, check the rear gears.
          • 15Michaeljoseph
            • Aug 2013
            • 1693
            Yeah, I would believe you've got an internal issue with the transmission. My thinking is that since it goes forward just fine, the clutch/master/slave/pivot etc. system is working as it should. All new shifter bushings means there's not going to be nasty slop in the linkage to mess with getting in reverse. Drilling down into the trans itself, your detent pins and internal selector stuff must be sort of working, since you're getting the switch to activate to turn on the reverse lights. I'm not super well versed in the anatomy of a transmission, but I would bet that the culprit lies there, rather than in the reverse gearing itself... Either way my bet is you're going to need to fix/ replace that transmission. Sent from my moto g(6) using Tapatalk
            • Vincenze
              • Apr 2019
              • 1029
              There is a transmission rebuilder in SoCal.
              • roguetoaster
                Biggus Tippus
                • 7830
                As stated above, likely transmission issue, providing you have your shift linkage set up correctly, with every item installed the right way, on the right side.
                Beyond that I wouldn't worry about it too much, as you can likely live without reverse 99% of the time.
                • ajfancypants
                  • Oct 2020
                  • 7
                  To follow-up on this it turns out I installed the shift lever backwards. I rotated it 180 degrees and I can reverse now. I also noticed that I have to firmly put it into gear and ease of the clutch verrrryy slowly or it will 'slip' out of gear and not reverse.
