I can’t get this thing to idle properly. I know, that’s every topic in here.. smh
  • Amcubayt
    • Feb 2021
    • 18
    The car drives great when you press the gas. In fact the cold idle is great too. The problem I’m seeing is that it’s not idling properly when the engine is warm. Above is a video that has me starting the car and showing how it sounds and shakes.
    • Amcubayt
      • Feb 2021
      • 18
      Also fuel pressure is something I have yet to check..
      • Amcubayt
        • Feb 2021
        • 18
        I just ran the car for a bit and I would let it rev at about 800 rpms and i felt the miss so I don’t think this is just an idle issue. The car at all rpms it seems. I just notice it less when I’m driving.
        • roguetoaster
          Biggus Tippus
          • 7830
          Oh, so it's a miss, that makes it sound more like a flaky CPS.
          • Amcubayt
            • Feb 2021
            • 18
            Thanks for the input. Is there any way to test the cps?
            • roguetoaster
              Biggus Tippus
              • 7830
              Yes, should be easy to find the procedure with a quick search.
              • Amcubayt
                • Feb 2021
                • 18
                Thank you
                • Amcubayt
                  • Feb 2021
                  • 18
                  So I just want to add some info to this post..
                  today I was just messing around checking out wiring, making sure the fuses were good and I went to start the car and it wouldn’t start at all which was weird because I never had that problem..
                  checked around again (basically changed nothing) and after a few more attempts, the car started. Then didn’t start, then started.
                  Is it me or is this sounding more and more like the cps? I checked the resistance and it seems fine. 550 ohms and I got the same with the wire reattached at pins 47 and 48.
                  Yup. Just an update.
                  • roguetoaster
                    Biggus Tippus
                    • 7830
                    Jiggle the wiring at the sensor end of the wiring while checking resistance, see if the values change.
                    • cheffy30
                      • Sep 2016
                      • 1159
                      just wondering ... if you put on a new cps when you did the timing belt last? they should easily last the duration between belt changes ~60k. perhaps it is the wires¿? sent from hell using Tapatalk
                      '90 325i sedan daily driven
                      '85 325e coupe also a daily
                      • Amcubayt
                        • Feb 2021
                        • 18
                        I’ll do that tomorrow and get back with you. If I change the sensor, is there any kind of resetting process I need to do?
                        • Amcubayt
                          • Feb 2021
                          • 18
                          Also, I did not put in a new cps when I changed the timing belt.
                          • Amcubayt
                            • Feb 2021
                            • 18
                            Update: I moved the cps around and the values stayed the same. Also, I bought a new cps. The car starts quicker, but still misses
                            • Gregs///M
                              • Mar 2012
                              • 2459
                              Assuming your ignition system is all good, consider a failing AFM or DME. Both are known to fail after these many decades.
                              Owner - Bavarian Restoration
                              BMW and European Electronics Repair and Restoration
                              www.BavRest.com
                              My Feedback Thread
                              Our Facebook!
                              Follow our Instagram!
