V12 swap help
  • projects5033
    • Oct 2023
    • 3
    V12 swap help
    Hello, I am currently in the middle of a m70 v12 swap on my e30 convertible and I am just wondering what wires I would need to start the car. I want to see if I can get it to run before I hook up all the lights and everything. Thank you
  • McGyver
    • 4637
    That's a really open ended question and I doubt you're going to get a straightforward answer. This is probably something you're going to need to figure out on your own. Look up the wiring diagrams for the donor car and the chassis here:
    • projects5033
      • Oct 2023
      • 3
      Thank you for the reply
      • 82eye
        • Jan 2009
        • 2075
        there was a speed shop in poland called pmc that had info and products pertaining to m70 swaps. i don't know if they are active right now due to the war in the region. the swap has also popped up in the netherlands and in sweden. there are likely companies there with products as well.
        • e30m3s54turbo
          • Jun 2010
          • 3289
          On my s38 b36 swap into my e30. I sent my wire harness to Andrew325is to match up with my e30. He sent back with labeling and wired diagram of harness.
