How steady is your idle?
  • Jean
    • 18228
    Is it rock solid, or does it wonder a bit? I am going to switch the ECU tomorrow and try another ICV. Hopefully it's one of those two, as I don't have another AFM or TPS...
  • jonmon6691
    • Aug 2009
    • 252
    Mine hunts right when I start it up but smooths out in a few seconds.
    <-- F*** that guy
    • StereoInstaller1
      GAS
      • 22679
      Mine is lumpy as hell, but certainly not "hunting"
      Closing SOON!
      Thanks for 10 years of fun!
      • Jean
        • 18228
        Cool. I am on my 2nd full tank of gas and told myself I'll drive like a grandpa.... keeping it under 3k rpm or trying.
        • StereoInstaller1
          GAS
          • 22679
          Jean, drive slowly as you look for moving boxes. that will keep it under 3K...
          Closing SOON!
          • chadthestampede
            • Jul 2008
            • 3601
            This. Ran pretty smooth at about 800 rpm IIRC.
            Originally posted by LJ851
            Feedback
            • bmw325csi
              • May 2007
              • 4045
              mine runs steady @ 800 with a rare surge once in a blue moon
              harry/harout
              • LowR3V'in
                • 4209
                Idles solid even on MS :P
                • Jean
                  • 18228
                  Mine is pretty solid, but sometimes it wonders up/down about 50 rpms. Maybe ICV needs cleaning....tomorrow.
                    • 34839
                    I know I have an M20 but the idle systems between M30s and M20s are the same (even M50s). it's smooth at 900rpm with MS2 controlling the PWM valve though. the worst my car ever idled was when it was 100% stock with a vacuum leak.
                    • Jean
                      • 18228
                      Gotcha. I don't think there is vacuum leak anywhere as pretty much everything is new, but the ICV / AFM are used. I don't think lack of airbox would affect the idle, what do you think?
                        • 34839
                        no it shouldn't
                        cleaning the ICV is pretty easy. carb cleaner works fine.
                        make sure everything is tight of course.
                        • Jean
                          • 18228
                          Cleaned the ICV and adjusted TPS on the TB and that fixed it :)
                          Bad news is my A/C Fan quit working...both relays are clicking but fan won't spin at low or high speed. Didn't have correct relays on hand so I'll replace them first before putting another fan in...
                          I really should look into SPAL fan...
                            • 34839
                            bad low speed resistor? but neither speed works now. probably a dead fan.
                            these fans are pretty old, not surprised when they stop working, especially since they go unused 90% of the time. Mine worked as the only cooling fan until I smashed it, but it was loud, balky and drew a lot of power. a new 16" fan is a good upgrade.
                            • Jean
                              • 18228
                              I have a spare from my 89, it's got different shaped blades so maybe it's a little bit quiter until I save up for a new SPAL fan. What fan did you get? How many CFM and how quite is it compared to the a/c fan?
