How steady is your idle?
  • Jean
    • 18228
    #31
    Flash - yeah it's a correct hose with a small side nipple for a vacuum line. Replaced the e30 ignition coil with the smaller e32/e34 coil and it didn't make a difference although it looks cleaner lol. I noticed that if the engine is running and I unplug the ICV idle doesn't shoot up like it did on my m10 when I did the same thing. I need to maybe find another ICV.
    • Jean
      • 18228
      #32
      Well, tried another ICV today, no difference. Still has this 30-50rpm hunt going on at idle.... it just bugs the shit out of me.
      Also tried unplugging the o2 sensor, no difference.
      • Jean
        • 18228
        #33
        Fixed. I did not put a clamp on the big hose that goes from the intake manifold to the ICV. I honestly didn't think it needed it since it was such a tight fit. Today while letting the engine idle I started feeling / moving that hose a bit and it changed the idle. Stupid me.
        Rock solid now.
        • Doughnut
          • Oct 2007
          • 869
          #34
          Rock solid now.
          Glad to hear you got it worked out!
          Really appreciate you following up on figuring out your problems :D
          ///Monstrosity. (OO≡≡[][]≡≡OO)
          Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
            • 34839
            #35
            Rock solid now.
            I've never had one on there. Maybe something with the swap is making the intake pull on the boot and causing a leak? if the hoses are all new it's pretty tight. but at least you found it!
            • Jean
              • 18228
              #36
              Nothing is grabbing on the hose, but the hose is soft (new). I could feel it "collapse" or change it's shape a little bit while the engine was idling. As soon as I put the clamp on there it stopped. Now to test this dinan chip lol
              • Jean
                • 18228
                #37
                Here is a quick video clip -
                It's good enough for me.
                • drift
                  • 566
                  #38
                  Just FAIL emission test.
                  Well, 1 out of 2 is the issue,
                  which is IDLE - emission is too high.
                  5 speed manual.
                  With 92 Octane gasoline.
                  Currently idles at 830 rpm - 930 rpm.
                  New OEM O2 sensor.
                  Runs and drives great, no smoke, no funny noise.
                  IDLE
                  Limit 220, currently at 456 = FAIL
                  CRUISE:
                  Limit 150, currently at 118 = PASS
                  What would be the culprit...
                  ( Since this test was done with NO catalytic converter, Yes i know...,but why it passes the "cruise limit", but not "idle limit" ) ?
                  http://www.kingofeurope.net/2010/
                  • Jean
                    • 18228
                    #39
                    You tried to pass w/o a cat? I don't think there is anyway you can pass w/o one, especially on idle when the emissions are usually at their highest....
                    • Gesucht
                      • Nov 2009
                      • 100
                      #40
                      I know this might be off topic,
                      but if u haven't tried or heard about mid 90's Honda Civic,
                      FYI, it EASILY passes emission test with NO catalytic converter.
                      At least i've done it twice.
                      Just .02
                      • george graves
                        • 19996
                        #41
                        I can't see a huge 3.5L straight 6 with very early fuel injection system doing that. It was not made to be a super clean running motor.
                        BTW - I've got a steady idle. Huts a bit when cold out (40 deg and below)
                        Originally posted by Matt-B
                        • Gesucht
                          • Nov 2009
                          • 100
                          #42
                          Or, maybe with Mark D chip ( upgrade) would helps a little ?
