M62 Swap
  • Jonsku
    • Oct 2004
    • 566
    For me it took 2 winters, but if you have the money and time, it can be done in couple of months.
    Originally posted by mkcman17
    does the shifter come close to the right location with the 6spd gearbox or do the linkages need to be altered? also, i've read that the 535 radiator is best? also, what driveshaft are you using?
    Yes, you should start with assumption "everything has to be modified". The only original, unmodified part i've in my engine room is the fuse box. Everything else is remade / modified.
    E28 535 radiator is a bit small, though it's the biggest one can fit "bolt-on" so that's why people use it. I got mine custom made. Driveshaft has to be modified (the 6-speed flange is much bigger than any E30 flange).
    There's lots of info on M6x E30 swaps on internet, check out at least e30.de, e30tech, e30zone, bimmerforums.
    - E34 M5 (x 2) -
    - E30 V8 Cabrio "Kylpyamme" -
    - Alpina D10 Touring #33/94 -
    - E46 318i Touring -
    - Toyota Hiace 4wd -
    • mkcman17
      • Jul 2010
      • 8240
      yeah i've been doing my research but my experience is that every swap experience is different, so it's good to hear the different ways people get through it. i forgot i'm a member on e30t too so i'll search over there as well.
      1989 LN106 Hilux / 3.0TD SFA
      1974 2002tii / stock
      2002 IS300 / 5spd LSD
      • Lorenzo
        • 1
        Great swap idea
        Hi there. I'm preparing for the same swap. M62 engine with 6 speed gearbox waiting. There is a lot to do about the electrical connections... CAN or no CAN on these models. I plan on taking on the machanical stuff first, worry about the rest later. The guy from E30.de seems to have everything figured out.
        • Jean
          • 18228
          probably easier to run it as obd1 m60 ?
          • Holland
            • Nov 2008
            • 7209
            Fucking do it, seriously that would be so badass. If you have access to such a complete setup.
            Originally posted by DEV0 E30
            • mkcman17
              • Jul 2010
              • 8240
              it was taken off the market until the insurance ass-juster looks at it
              • bimmernut2
                • Apr 2009
                • 5
                Hey man I just finished the same swap , My engine and trans also came from a 97 540 and I tried the original wiring,like the man said if you go with the obd 2 its a pain ,I went with obd 1 from 94 740 ,had to change the front housing ,crank pick up ,change the knock sensors ,modifly the cam on the rt side( fab a shim for cam gear) fab a spacer for cam position sensor and wiring harness . runs. very strong ,screemer as a matter of fact, but took me longer than a year but only worked on it in spare time. still waiting for a few odds and ends the exhaust is the hardest but with X5 header you only have to mod one side, and of course make the compete exhaust system back.will send pics if u want and its for sale. I only wanted to do the build for the fun of it so now ready for a new project.
                • Jonsku
                  • Oct 2004
                  • 566
                  Could you take some pictures of the X5 manifolds in place, thanks!
                  - E34 M5 (x 2) -
                  • Paukert11
                    • Nov 2008
                    • 1295
                    Do it. I just upped my build. Im puting a turbo on it
