Harmonic Balancer:1 , Breaker Bar:0
    • 34844
    er yeah, all you need to do is remove the 6 pulley bolts.
    • ericgoum
      • Jan 2010
      • 15
      As the last 2 posts point out, I in fact did not need to remove the crank bolt to remove the harmonic balancer. I remember trying to remove it with my hands after taking out the 8 bolts that hold it along with a pulley in position and it wouldn't move. So I assumed I needed to take off that big bolt instead of just pry off harmonic balancer with something more than my hands. Definitely a noob mistake that most likely won't be my last during this engine swap process. Thanks for all the replys/solutions to my make believe problem!
      Eric
      • whodwho
        • Jun 2008
        • 1547
        A couple screw drivers, one on each side and rock it back and forth should walk it off.
        Is this going back on a M30?
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
        • ericgoum
          • Jan 2010
          • 15
          Yeah, this is going on either a B34M30, M90 or hybrid of the 2. I won't know what I'm going to do until I get inside both of the motors. The plan is then to put it in my 325e. Then sometime down the road turbo it.
          • whodwho
            • Jun 2008
            • 1547
            Very nice, make sure to post it up when it happens!
