Thanks for the help!! When you say you adjusted the air going in, how did you do that? By way
of the Air Meter?
Kris
On the throttle body your able to adjust how much air goes through your intake manifold at WOT with just a couple turns with a philips screwdriver, I know on mine when i would open the throttle all the way it would bog out at 3500 rpms did a couple turns and that fix the problem hope this helps in the long run GL:up:
of the Air Meter?
Kris
