Valve train noise - be gone?
  • Jean
    • 18228
    Cheap - you guys should do this :)
  • LowR3V'in
    • 4209
    It's a must for the m30 owner.
    About 3 years ago I started doing this and WOOOOWW it eliminated
    all valve tick. If you guys don't know about this go do it ASAP.
    Just adjust at the CAM to .008 or 9.
    Leave the sowing machine sound to the m20s ;)
    • wannaBMthree
      • Apr 2007
      • 601
      :cheers:
      • u3b3rg33k
        • Jan 2010
        • 2452
        So are you saying that M20s sound like sewing machines no matter what?
        Ich gehöre nicht zur Baader-Meinhof Gruppe
        Originally posted by Top Gear
        Just imagine waking up and remembering you're Mexican.
        Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
        • bmwstephen
          • 2463
          my m20 sounds smooth with no ticking after a proper valve adjustment from an actual e30 specialist (aka Ryan G). I'll take a video later to prove it
          • LowR3V'in
            • 4209
            No, just buy the parts that wear so you can get good measurements again.
            or adjust at the cam like allot of m30 guys do.:borg:
            • u3b3rg33k
              • Jan 2010
              • 2452
              please do. I'd love to shut mine up without burning valves. Post some cam side clearances?
              • Heysüß
                • 911
                as soon as my overheating (I didn't bleed my coolant system) stops this is next on my purchase list. thanks for this! :)
                09/1989 325i 4 Door
                +M30 Swap
                +Z3 Steering Rack
                • E30 Beast
                  • Jan 2010
                  • 182
                  GL on this one, in the process of solving my overheating issue as well
                  • Heysüß
                    • 911
                    I just bled the system since I forgot to and that fixed it, I'd completely forgotten you need to do that, haha.
                    09/1989 325i 4 Door
                    +M30 Swap
                    +Z3 Steering Rack
                    • E30 Beast
                      • Jan 2010
                      • 182
                      Need some help just did a valve adjustment completely wrong (misread some info), now car has rough idle, could I just redo the valve adjustment the proper way or is there another step I need to take
                      Mark
                      • VinniE30
                        • 2113
                        Mark
                        What did you do wrong?
                        Zinno '89 <24v swap in progress>
                        • E30 Beast
                          • Jan 2010
                          • 182
                          I didnt adjust the valves per cylinder, I just jumped around everyone I seen a lobe down
                          • Lurker27
                            • 821
                            You can do that, but you have to turn the engine at the very least twice. I used a sharpie to mark the properly adjusted rockers.
                            '89 335is +turbo
                            • E30 Beast
                              • Jan 2010
                              • 182
                              must of adjusted them too tight then, went with the .008 feeler gauge on a rebuilt head
