Valve train noise - be gone?
  • LowR3V'in
    • 4209
    Did you do .008 on the cam or did you measure at the valve?
    If it's at the valve that's way too tight.
    The motor is at an angle so remember have the lobe pointing the right way.
    • E30 Beast
      • Jan 2010
      • 182
      Measured from the cam side, gonna try again in an hour or so
      • u3b3rg33k
        • Jan 2010
        • 2452
        And?
        Ich gehöre nicht zur Baader-Meinhof Gruppe
        Originally posted by Top Gear
        Just imagine waking up and remembering you're Mexican.
        Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
        • E30 Beast
          • Jan 2010
          • 182
          Okay so I did another valve adjustment and the valves sound great but the car runs like shit, the idle constantly jumps up and down, do u think the compression is off a tad bit
          • u3b3rg33k
            • Jan 2010
            • 2452
            I did mine to .008 last night, and it's much less clacky. I think .007 would be ideal, but I couldn't find that set of feeler gauges.
            • E30 Beast
              • Jan 2010
              • 182
              My question is can u mess up the compression if the adjustment was done wrong
              • u3b3rg33k
                • Jan 2010
                • 2452
                You can burn your valves if you don't let them close.
                • LowR3V'in
                  • 4209
                  Maybe it's something else wrong with your car.
                  • E30 Beast
                    • Jan 2010
                    • 182
                    I think the valves are still tooo tight because it ran fine before, going to give it another try tomorrow
                    • Doughnut
                      • Oct 2007
                      • 869
                      Even if you adjusted the eccentrics right down onto the cam lobes (without a feeler gauge) it wont cause your erratic idle problem.
                      When you pulled the valve cover you could have disturbed some vacuum lines introducing a vacuum leak.
                      Recheck your hose clamps and hose connections.
                      Joseph.
                      ///Monstrosity. (OO≡≡[][]≡≡OO)
                      Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
                      • E30 Beast
                        • Jan 2010
                        • 182
                        Thanks too everyone who gave me great advice really helped, one valve on #6 was way too tight nd when I say too tight I mean not even feeler gauge .006 would fit in between, fixed that problem thanks again guys
                        • george graves
                          • 19996
                          Thanks for the link Jean. My m30 is starting to clack a bit.
                          Originally posted by Matt-B
