I already said this as well.
Sensor is not showing lean, the high NOx shows his combustion temps are too high, which is usually lean or faulty EGR - since there is no EGR, it points to lean conditions in the chamber.
EDIT: Even a brand new o2 sensor is not sensitive enough to know if it's a few points lean, it only tells the ECU when it's VERY lean/rich. Hence the name "narrow band".
