m30b35 supercharged
  • csermonet47
    • Jul 2009
    • 937
    Interested to see how this goes. I hope you follow through with it!
    Are Three Vee
    Dad Spec
    • Click
      • 637
      Yeah interested to see how this goes. I've been weighing SC vs turbo for my b35 but I've pretty much decided on the turbo since SCs usually rob about 10% of your power, but the low end power is nice.
      ส็็็็็็็็็็็็็็็็็็็็็็็็็
      I need you to exfoliate my ballsack
      Build Thread?
      • george graves
        • 20003
        So - when adding something like an eaton m90 to an m30b35, how is the gas mileage when you're just cruising around town? Are you really only using more gas when you're on the gas/rev's a lot? How does that work?
        Originally posted by Matt-B
        • LowR3V'in
          • 4209
          It must be real bad.
          How much boost you get at 2,500rpm?
          I get about 13-14mpg with a turbo.
          • george graves
            • 20003
            ^no offense - but sounds like you're just taking a wild guess. I don't know the answer either - that's why I'm asking.
            Doing some reading -there are people that claim to get better gas mileage with the SC (on the freeway)
            Many people assume a blower is making boost 100% of the time. In actuality, the blower normally only goes into boost when the throttle is opened substantially or when the vehicle is under load, such as going up a steep hill or pulling a trailer. In order to make boost, the blower must get air, and during most driving you will only have the throttle open a slight amount. Interestingly enough, even when not making boost, the spinning rotors improve the volumetric efficiency of the engine to the point where you can maintain high cruising speeds at lesser throttle openings, and in normal driving around town, you will notice that the vehicle is much livelier even when not making boost. This phenomenon can improve gas mileage under certain circumstances, although typically on an overall basis fuel economy will decrease about 3%. This isn't much of a factor. If your car was getting 20 mpg before the blower that means you will be getting 19.4 mpg after the blower installation but with a 40 to 50% increase in horsepower.
            Twin-Screw and Roots type superchargers are very common on Truck applications where people desire most torque and horsepower for towing and off the line power. It is also very commonly used for road course racing where more instant power is needed. The characteristic of a Twin-Screw and Roots type supercharger normally provides boost instantly. Unlike the Centrifugal type superchargers you do not need to wait until redline to see the higher boost levels for it normally will be present throughout the whole RPM band. Because of the boost curves this type of supercharger is idea for anyone seeking a lot of HP and Torque instantly, which makes it perfect for towing heavy loads or someone that needs the extra power in the lower, mid, and higher RPM range.
            ^ That makes me excited
            Also, for a street car....
            Also, the additional low end torque allows for a taller rear end ratio
            • yert315
              • 2734
              I am still curious on how you plan to run the belt(s). I see you mentioned custom crank pulley. Will you be running a serpentine belt setup?
              • Woofer
                • Aug 2005
                • 82
                Sweet build! Let's see some pics!
                • CHIF8008
                  • 3447
                  man i always wanted a M30 supercharged
                  so down for slightly less MPG but much more power
                  -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                  -The Beauty in the Tragedy-
                  MECHANIC SMASH!!- (you all know you do it)
                  Got Drop?? ;-)
                  But of course
                  E30s are know to be notoriously really really really ridiculously good looking
                  • cheapshot
                    • 451
                    You and me both! I have every intention to and hope that I don't hit any snags that would cause me to abandon it. The good news is that this is not my dd so I can take my time and make sure that it is done right.
                    This is true, but I will take the 10% thievery for the 50% bump in power and low end torque!
                    Mpg is really not a big concern for this project but I doubt it would be any worse than a turbo setup, should be better. Also, the amount of boost at a given rpm is completely dependent on the pulley ratio.
                    This is a very interesting question. I am not 100% sure on this yet. My original plan was to run a dedicated serpentine belt off of the crank to the sc, however, I have a buddy of mine who thinks I should do one single serpentine belt to drive it and the accessories. That seems to be a much more difficult route to go as I would have to make sure that all other components are being driven at the proper ratio.
                    And George, thanks for posting the info on the SC's! Where did you come across that?
                    • RagtopE30
                      • Dec 2010
                      • 1869
                      Greg, Just spend some quality time measuring your OE accessory pulleys, shaft diameters, and (well I hate to use wheel terminology but) offset. Once you know these your local decent auto parts store should be able to help you find the pulleys for your application without the cost of custom pieces.
                      450whp 524 lb-ft 1988 336ic In progress
                      http://www.r3vlimited.com/board/showthread.php?t=250709
                      • cheapshot
                        • 451
                        Are you referring to if I go with a complete serpentine setup?
                        • cheapshot
                          • 451
                          So these are the parts that I picked up today.
                          Eaton m90 SC with charge pipe and intake
                          FMIC
                          RRFPR, not sure if this is the one I am going with. It was a freebee and that scares me.
                          Misc. Charge pipes and bends
                          Innovative wide band (still need the innovative gauge)
                          Parts still needed
                          Maybe BEGi RRFPR (I have a line on this from another forum member but have yet to pick it up)
                          Coupler kit (I have a line on this from another forum member but have yet to pick them up)
                          Innovative wideband gauge
                          Boost gauge
                          Oil pressure gauge
                          Anything I am forgetting?
                          • RagtopE30
                            • Dec 2010
                            • 1869
                            Yes full serpentine
                            • slammin.e28
                              שמע ישראל
                              • 12054
                              In for this.
                              I'd love to FI my e28, but just put headers on it and don't wanna fuck with them again.
                              • ForcedFirebird
                                • Feb 2007
                                • 8300
                                Yes full serpentine
                                Don't need to go full serpentine. Just use a ribbed belt, tensioner and add a second pulley for the front of the v-belt crank pulley.
                                john@m20guru.com
                                Links:
