Originally posted by G-Man the Visionary
View Post
- I dunno about different m30 bellousings, but all of the m30 w/AT bellhousings have looked the same to me.
- I am thinking yes the m20 harness woudl be A-OK; I spliced an m30 harness into my m20 harness right about a foot after it comes out of the firewall. I had to work with a cut m30 harness and only part of an m20 harness.
- No, no electronic hookups as long as you are using the 4hp22, not the 4hp22eh, which is the electronic one found on later 5 series and has its own TCU, harness and a switch or two.
- Get a new kickdown cable for your transmission as it has a seal at the end it connects to the transmission (same withe selector shaft seal - both of these are about impossible to do without dropping the AT) I got the one for the e30 but it has the wrong end on it for the m30, so I brazed on the right cable end. Or you could just get the one that has the right end - this would be from an early 5 series that used the non-electronic transmission, as the electronic doesn't have a kickdown cable. That being said, you may have to cut and braze on the end to get the length right from where it connects to the bracket. THE BRACKET: you'll need to fab one to hold the kickdown cable, unless the 735iL was early enough to use the non-electronic transmission. There are two different throttle bodies - one allows for full throttle, then a bit more for the kickdown, the other is just a plain throttle body, where if you want 100% throttle you get the kickdown. .
